thinning bondo with fiberglass resin
Discussion in 'The Hokey Ass Message Board' started by v8nova64, Aug 23, 2011.
  1. davidbistolas
    davidbistolas
    Just grab a hunk of it and chuck it at the panel. Sprayers are for wimps.
  2. ChevySteve406
    ChevySteve406
    This is an old post, however, what I didn't hear in the comments was experimenting first and decide if you think it is what you wanted or not.
    RyanG1979 likes this.
  3. ech52
    ech52
    What I love about the net is all the bs from all the experts. Did any of you stop to ask 3M? It took exactly 12 minutes for them to come back with the answer. Can Bondo Body Filler be thinned? Yes! Up to 25% with fibergl*** resin. Use the cream hardener. Drying time will be slower. Do not use Acetone, MEK, Alcohol or brother in laws pee.
    RyanG1979, lippy and AccurateMike like this.
  4. lippy
    lippy
    from Ks
    It's like I asked 3M , can you use panel bond for filler? They said no. Thats why we make filler. :confused: LOL
  5. Utahvette
    Utahvette
    As a young know it all, I thought I could save big money by making my own "Featherfill" by thinning "bondo" with styrene (the proper way to thin polyester resin). It would be half the cost, if it worked. Well , it worked as far as spraying it on the fender, and it hardened, pretty much. But it clogged sandpaper liked crazy. I ended up s****ing it all off. I suspect it's like jell-coat in that you must seal it off from air , or have a surfactant in the solution to get the surface to harden. Long story short, real polyester primer is worth the extra cost.
    JNKYARDDOG_1 likes this.
