Technical This can’t be right
Discussion in 'Traditional Hot Rods' started by chris101_ny, Apr 15, 2025.
  1. chris101_ny
    chris101_ny
    This can’t be right?! I’m installing new shoes and hardware on model A with Ford F1 hubs. The hardware, at the suggestion of fellow HAMBers, I have bronco rear shoes and hardware. The spring is getting caught up in the adjuster. I only found 2 pics online and they both had the same issue. If it’s not right, any info to correct the situation would be helpful. Also, the hold down pins are longer than the ones I took off the car. Not sure if that will be a problem.
    Thanks!!
  2. alchemy
    alchemy
    Yes the spring is supposed to keep the adjuster from spinning on its own. And, I’d suggest finding the proper length hold down pins. Take the old ones to your local parts store for comparison.
    GordonC, big duece and dana barlow like this.
  3. Dooley
    Dooley
    from Buffalo NY
    1956 Chevy Rear brakes from the Web
    dana barlow likes this.
  4. If you really have Bronco hardware I'd expect self adjusting brakes, and that's not what you have there. Otherwise for manual adjusting brakes of older Fords with self energizing brakes what you have looks to be correct.
  5. Jeff34
    Jeff34
    What @alchemy said. As you turn the adjuster, you'll hear the spring snapping past the teeth of the adjuster.
  6. 19Eddy30
    19Eddy30
    from VA
  7. jaracer
    jaracer
    The spring does keep the adjuster from turning. However, it looks like you have a fine tooth adjuster that is normally found on self adjusting brakes. The ones for non-self adjusting have larger and fewer teeth.
  8. swade41
    swade41
    from Buffalo,NY
    My bronco self adjuster spring
    rod1, Budget36 and mad mikey like this.
  9. squirrel
    yup, like this. With teeth that are the right size and shape for getting a brake s**** in there to adjust them.
  10. gimpyshotrods
    gimpyshotrods
    I am seeing a tie rod end in the left of the picture. On a Model A, or similar, the steering mechanism is behind the axle.
    That being the case, you have your brake shoes in the incorrect positions.
    The shoe with the shorter lining is the leading shoe (primary), and the one with the longer lining is the trailing shoe (secondary).
    In order for the servo action to work properly on Bendix-style brakes, the leading shoe MUST be in the front.
    In your picture, it is in the rear.
    AccurateMike, alanp561 and squirrel like this.
