this custom 9 inch a decent deal?
Discussion in 'The Hokey Ass Message Board' started by wex65, Feb 1, 2013.
  1. wex65
    wex65
    from WV
    Been talking to a co about getting a rear end with a custom width for a '30 Model A.
    This is what I have from them, is this reasonable?
    <!--[if gte mso 9]><xml> <w:WordDo***ent> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:TrackMoves/> <w:TrackFormatting/> <w:punctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:DoNotPromoteQF/> <w:LidThemeOther>EN-US</w:LidThemeOther> <w:LidThemeAsian>X-NONE</w:LidThemeAsian> <w:LidThemeComplexScript>X-NONE</w:LidThemeComplexScript> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> <w:SplitPgBreakAndParaMark/> <w:DontVertAlignCellWithSp/> <w:DontBreakConstrainedForcedTables/> <w:DontVertAlignInTxbx/> <w:Word11KerningPairs/> <w:CachedColBalance/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> <m:mathPr> <m:mathFont m:val="Cambria Math"/> <m:brkBin m:val="before"/> <m:brkBinSub m:val="&#45;-"/> <m:smallFrac m:val="off"/> <m:dispDef/> <m:lMargin m:val="0"/> <m:rMargin m:val="0"/> <m:defJc m:val="centerGroup"/> <m:wrapIndent m:val="1440"/> <m:intLim m:val="subSup"/> <m:naryLim m:val="undOvr"/> </m:mathPr></w:WordDo***ent> </xml><![endif]-->[FONT=&quot]Here is what we can do on a complete 9" Ford Rearend for you:
    $725 - 9" Housing/Axle Package (Bare - Custom)
    - Custom Length (Please Specify)
    - New Moser Axles, Axle Bearings, Wheel Studs, & Retainers
    - 31 Spline, 5 on 5-1/2" Bolt Pattern, 1/2" Studs
    $820 - Center Section (***embled)
    - New 31 Spline Trac-Lock Posi
    - New Motive Performance Gears (Choice of Ratio)
    - New Timken USA Bearings
    $1545 - TOTAL
    This would be a complete 31 spline setup with your choice of gear ratio. All of our housings are jig-welded with new 3" DOM tubing. We use new Moser axles, not factory re-splines. In the center section we use a new Ford Motorsports Trac-Lock Posi Unit that has a nodular iron case and a billet steel hat, not a Torque-Lock unit (modified open carrier) like others are selling on eBay. We also offer a Detroit Locker Unit, a full spool, as well as a standard open (one wheel) carrier. If you would rather go one of these routes let me know and I will get you some updated prices.
    As for the brakes, we have a complete 9" Ford 11" Drum Brake Kit for $300 and Disc Brake Kits for $239 (w/o parking brake) or $369 (w/ parking brake). We also offer a full line of Wilwood Disc Brakes.[/FONT]<!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="true" DefSemiHidden="true" DefQFormat="false" DefPriority="99" LatentStyleCount="267"> <w:LsdException Locked="false" Priority="0" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Normal"/> <w:LsdException Locked="false" Priority="9" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="heading 1"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 2"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 3"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 4"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 5"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 6"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 7"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 8"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 9"/> <w:LsdException Locked="false" Priority="39" Name="toc 1"/> <w:LsdException Locked="false" Priority="39" Name="toc 2"/> <w:LsdException Locked="false" Priority="39" Name="toc 3"/> <w:LsdException Locked="false" Priority="39" Name="toc 4"/> <w:LsdException Locked="false" Priority="39" Name="toc 5"/> <w:LsdException Locked="false" Priority="39" Name="toc 6"/> <w:LsdException Locked="false" Priority="39" Name="toc 7"/> <w:LsdException Locked="false" Priority="39" Name="toc 8"/> <w:LsdException Locked="false" Priority="39" Name="toc 9"/> <w:LsdException Locked="false" Priority="35" QFormat="true" Name="caption"/> <w:LsdException Locked="false" Priority="10" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="***le"/> <w:LsdException Locked="false" Priority="1" Name="Default Paragraph Font"/> <w:LsdException Locked="false" Priority="11" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Sub***le"/> <w:LsdException Locked="false" Priority="22" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Strong"/> <w:LsdException Locked="false" Priority="20" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Emphasis"/> <w:LsdException Locked="false" Priority="59" SemiHidden="false" UnhideWhenUsed="false" Name="Table Grid"/> <w:LsdException Locked="false" UnhideWhenUsed="false" Name="Placeholder Text"/> <w:LsdException Locked="false" Priority="1" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="No Spacing"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 1"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 1"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 1"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 1"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 1"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 1"/> <w:LsdException Locked="false" UnhideWhenUsed="false" Name="Revision"/> <w:LsdException Locked="false" Priority="34" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="List Paragraph"/> <w:LsdException Locked="false" Priority="29" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Quote"/> <w:LsdException Locked="false" Priority="30" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Intense Quote"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 1"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 1"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 1"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 1"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 1"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 1"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 1"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 1"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 2"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 2"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 2"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 2"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 2"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 2"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 2"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 2"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 2"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 2"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 2"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 2"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 2"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 2"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 3"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 3"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 3"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 3"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 3"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 3"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 3"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 3"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 3"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 3"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 3"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 3"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 3"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 3"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 4"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 4"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 4"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 4"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 4"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 4"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 4"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 4"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 4"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 4"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 4"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 4"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 4"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 4"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 5"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 5"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 5"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 5"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 5"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 5"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 5"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 5"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 5"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 5"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 5"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 5"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 5"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 5"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 6"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 6"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 6"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 6"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 6"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 6"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 6"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 6"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 6"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 6"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 6"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 6"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 6"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 6"/> <w:LsdException Locked="false" Priority="19" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Subtle Emphasis"/> <w:LsdException Locked="false" Priority="21" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Intense Emphasis"/> <w:LsdException Locked="false" Priority="31" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Subtle Reference"/> <w:LsdException Locked="false" Priority="32" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Intense Reference"/> <w:LsdException Locked="false" Priority="33" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Book ***le"/> <w:LsdException Locked="false" Priority="37" Name="Bibliography"/> <w:LsdException Locked="false" Priority="39" QFormat="true" Name="TOC Heading"/> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} </style> <![endif]-->
  2. King Karl
    King Karl
    from N.C.
    Looks like retail pricing to me or maybe a bit over.
    I purchased my axles from Moser for around $450 but they also have different levels of axles available. Had the housing narrowed locally for $100.
    The center section sounds close given that it's using new parts. Would the nodular case be new or an older one?
  3. Crystal Blue
    Crystal Blue
  4. Don's Hot Rods
    Don's Hot Rods
    from florida
    To me those prices seem about right. Sounds like some quality parts, like the Moser axles and Track-loc center section. I am running the same Track-loc and am glad it is the one I chose.
    All in all, I think I would pay that price. I would take the brake deal too, as it saves a lot of running around and $300 isn't out of line.
    Don
  5. Crystal Blue
    Crystal Blue
    or pop another $69 for discs, depending on the OP's type of build.
  6. Yep, full retail. No real deal here.
    I've got roughly 1/2 that into mine and mine is built stronger.
    I see they say that the posi has a nodular case but they don't mention that the center section is nodular. Nothing like putting bullet-proof parts into a paper mache case. BUT..........
    Do you really need that much rear end? Are you racing? Do you have a lot of power? Overkill = Overspent
  7. Crystal Blue
    Crystal Blue
    FWIW, I puchashed all my parts separately, 57 Ford housing, "N" case, Nascar pinion bearing support and pinion yoke, Moser 31 spline axles, Detroit soft locker, Precision Gear- Ring & Pinion, 9" master overhaul kit, and Wilwood discs. It ended up costing a little over $2k. I should've gotten a complete unit :)
  8. wex65
    wex65
    from WV
    To be fair the comment about whether I need that much rear end is one that resonates with me...I hear you.
    Thanks for all the feedback though. It is helpful.
    I might stick with the early Bronco unit I picked up.
    Car is fenderless highboy, nailhead, 3 deuce yada yada.
  9. A Ford 9" is a smart way to go.
    But to have Moser axles, 31 spline and nodular parts when they are not necessary, well........ Let's just say that you could use that, extra money spent, on more important things.
    Yea, we all love to make things bulletproof so we won't have any issues. But installing a stock 9" in a lightweight car with 300 or so horse will be bulletproof enough.
    And if you have nowhere else to spend the extra money...... buy me a beer!
  10. Don's Hot Rods
    Don's Hot Rods
    from florida
    I've always gone the junkyard rear end direction because I couldn't afford a brand new setup, but my Son bought his from American Autoweld and it sure was nice working with everything brand new. No grease or rust to s****e off, no extra brackets to cut and grind smooth, no axle bearings to replace, and no running all over the place for parts to replace those that were worn out.
    We are doing two OT cars right now and both will get brand new rear end ***emblies because in the end the price isn't all that much different when you factor in your time and labor.
    Don
  11. That's an interesting way to suspend it Don!
    I prefer to take the "scrounge" method.
    Right now there are guys in the Charlotte, NC area selling new axle housings on the Charlotte area Craigslist for $100.00. My Nodular cases I find all over... Craigslist, swap meets, junkyards, RacingJunk, etc. I run a spool and I can find them, in new condition, at swap meets for $75.00. The gears depend on what's out there. Some I find used but never used, others I buy new. Axles depend on what I'm dealing with. Some I'll use re-splined Ford axles and some I go with Moser.
    When I buy new the internet is my best friend and I'm not referring to Evil Bay. I'll Google the part number, that always gets me the part and all the places that sell it. Then I find the lowest price on the net, call Summit Racing, tell them that price and where I found it and Summit beats the price by 10%. My Moser axles with bearings, studs and retainers cost me $295.00 for the pair. And YES! I have the receipts!
    I also got my rear wheels & tires down from almost $1500.00 down to $874.00.
  12. black 62
    black 62
    from arkansas
    good middle of the road prices with quality namebrand parts ----doubt you will do much better on the axle and housing package
  13. FiddyFour
    FiddyFour
    love love LOVE the quarter elliptical 4-link setup... is the spring and mount from posies or speedway?
  14. HOTRODPRIMER
    HOTRODPRIMER
    Maybe I'm nuts but that's a heck of a lot of money,,I would stick with the bronco rear axle. HRP
  15. tommy
    tommy
    I'm just too f'n old and cheap. Y'all keep talking I like to learn how the elite live.
  16. Ha Ha Ha!!!
    I take cans and bottles back for the deposits so I can buy some race fuel. :D
  17. Rocky
    Rocky
    Classified Editor
    Same here. I thought I'd save some $$$$ by building my own 9 inch from ebay/HAMB cl***ifieds/local parts. Used a 57 housing with an "N" carrier housing, datona pinion bearing retainer and dutchman axles..rebuilt the posi myself...had a buddy set up the gears....had over 1400 in it before any brakes were bought! Could have saved money and time by just buying a complete unit also.
  18. TR Waters
    TR Waters
    from Vermont
    Sounds good to me. Half way through playing with the old junk, you will wish you had bought the new one. Bolt it in a go.
  19. mattrod68
    mattrod68
    like others have said, the 31 spline and internals seem over kill on a light car that will presumably not be able to hook up anyway (skinny tires im ***uming).
    not a bad price for new stuff and what it is though but do you need it?
    matt
  20. Don's Hot Rods
    Don's Hot Rods
    from florida
    Thanks. Started out as a Posies but everything got sliced and diced and some custom mounts built.
    Don
  21. mustang6147
    mustang6147
    from Kent, Ohio
    I like MOSER.... They have always been great to me. The tech dept will give you all the info, then give you a purchase order, then I call Summit, get the big discount, and have it shipped from Moser directly to me. I saved many $ to many times to count, and they are doin an overstock sale right now ta-boot
  22. Blue One
    Blue One
    from Alberta
    Depending on the theme of your build, you might like to consider Winters non quick change banjo style rear end.
    It's a really nice and stout rear with modern internals and all the features of the 9" rears you are looking at but with an old style look.
    A nice unit.
    http://www.wintersperformance.com/2010 Street Rod Rears Catalog.pdf
  23. NAT WILLIAMS
    NAT WILLIAMS
    Johns out of michigan $650 for new housing axles and bearings and used center section traction lock 323 gears $300. $950 total. 2 years ago.
  24. Mr48chev
    I've got to agree with HRP on that one. If you already have a complete rear end that fits why go out and spend that much money for something that is beyond overkill for what you intend to do?
    If you are building a car that is packing 500 + hp and will make a lot of p***es down the quarter then spending the money for a rear end with all the good stuff makes sense.
    But as several others said, if you want to go with a custom rear end shop and shop some more. Mosers, Currey and Dutrchmans all produce good stuff and their prices are right out there online to compare by. No doubt there are several others that can produce a good rear end with new pieces that has a compe***ive price too.
  25. DualQuad55
    DualQuad55
    from NH
    322 Nailhead with an early Ford topload 3spd does not need a nodular 9 inch rear. The Trans will likely be the weakest link in the driveline. You could get away with a properly rebuilt Ford Banjo rear.
    I would keep the Bronco rear, replace the seals, check the bearings and leave it alone. To freshen the Bronco rear should not cost too much, a couple hundred or less for good bearings and seals. Then if you want to spend more for a posi/limited slip unit you could. Even the 28 spline axles will be more than enough for you at this point.
    I dont think the prices you got are out of order, just not a necessary component for this build.
  26. wex65
    wex65
    from WV
    Guys
    Many thanks for the feedback.
    I was just trying to get a feel for how reasonable the prices were but the Bronco unit will indeed be sliding under the car. It is a 76 unit with large bearings.
    Been reading the thread that describes how to fit Buick drums to a 9 inch, every trip to HAMB is a learning experience.
    Paul
  27. kiwicowboy
    kiwicowboy
    from linwood nc
    that is a fear price for all new parts.
