Hot Rods This is what happens when you go to the G.N.R.S. and your furnace goes out!
Discussion in 'The Hokey Ass Message Board' started by rusty rocket, Feb 5, 2017.
  1. rusty rocket
    rusty rocket
    So I have a super insulated shop and it has never froze but we have had a brutal winter, nonstop cold weather. So back this spring I got my 32 sedan running after a nine year build. When we fired the motor we put straight water in it and of course I had some leaks to track down and fix so it wasnt to bad cleaning up without the sticky anti freeze. Well it just kicked me in the ***! I totaly forgot about it, I just ruined a vintage ***kickin 68 327 with only 4000 miles on the rebuild!!!! If any of you good HAMBers want to each donate a dollar I might be able to get a new mill! Ha Ha! What a dumb **** I am!!!! IMG_1686.JPG IMG_1692.JPG
    3340
  3. cretin
    cretin
    Aww man. Thats ****s.
  4. pat59
    pat59
    So sad. man that ****s.
  5. falcongeorge
    falcongeorge
    from BC
  6. That's a bad one. I've s***ched lots of blocks. But never one that bad.
    ****s.
  7. My sympathy on that one... have went through more or less the same thing but the cracks were in the lifter valley sides. Never leaked until years later after dis***embly and hot tanking the block. Found a lot of strange parts combinations in that engine.
  8. kidcampbell71
    kidcampbell71
    Damn. Homeowners Insurance ? It is a condition of home ..... just depends on you, and coverage. My OT boat had a m***ive sheet of ice, slide down the roof and kerplowie my cover, navagation, and steering controls. Made a 3700 dollar repair ALOT more affordable.
    BTW that ****s. Love that build. Good luck with everything. You'll rise again.
  9. rusty rocket
    rusty rocket
    So Im thinking to make it easy I,m going to just bite the bullet and buy a new crate motor. Need input on what to get. I dont have a deep wallet but I also dont want to just throw in a 290 horse replacement mill. Help!
  10. bchctybob
    bchctybob
    Bummer, a sweet little 327 bites the dust, damn. Maybe a good hearted local HAMBER will donate a block.....
  11. BJR
    BJR
    I feel your pain, what a bummer.
  12. Early Ironman
    Early Ironman
    I think if I only had 4000 miles on a well built 327. I would go out and find another block to machine.
    32Stoker, hipster, triman62 and 12 others like this.
  13. 117harv
    117harv
  14. DDDenny
    A moment of silence please.
    mad mikey, mgtstumpy, CBurne7 and 2 others like this.
  15. J. A. Miller
    J. A. Miller
    from Central NY
    I'm with Capt Chap on this - find another block and get it machined.
  16. Better off with a crate 350 in the overall long run. It will treat you well for many miles down the turnpike.
  17. RMR&C
    RMR&C
    from NW Montana
    Hard for me to admit, but you are not alone.......years ago I did the exact same thing with a fresh flathead V8. Still pissed at myself over that one
    Skankin' Rat Fink likes this.
  18. harpo1313
    harpo1313
    from wareham,ma
    Don't feel bad ,I threw 350 engine gear on a fresh 400 build and that didn't end well either.
  19. ClayMart
    ClayMart
    ooooofff... :(
    I just threw up in my mouth a little bit. (As the kids on the interwebs like to say.) :oops:
    BREIT1, Wurger and 98Racer like this.
  20. So very sad........
  21. sanfordsotherson
    sanfordsotherson
    from So. Cal.
  22. Roadsir
    Roadsir
    Argggh. If that happened to me I'd be too pissed to post! I feel for you. That's going to be a time consuming, and expensive lesson.
  23. badshifter
    badshifter
    I guess your freeze-plugs didnt get the memo.....
  24. Mr48chev
    A solid 327 block shouldn't be that hard to find.
  25. Kharma is a *****.
    paintslinger805 likes this.
  26. t time
    t time
    from ohio
    Bummer!! Crate 350 probably the way to go
  27. Mr48chev
    I've seen a number of engines that froze and were cracked just like his, plus one big block Mopar that cracked on the inside and the water pushed the oil out the top when we took the car in the school shop and left it in the heated shop over the weekend. I have never seen a core plug pushed out by freezing water in the 55 years I have been working on engines. Not saying it doesn't happen but they weren't put there to keep the block from cracking they were put there because the holes were where the mold held together and where the got the sand out after casting.
    hipster, Hnstray, kiwijeff and 5 others like this.
  28. Tony Fowler
    Tony Fowler
  29. Blue One
    Blue One
    from Alberta
    That really ****s. I like the fresh crate motor idea.
    That's the reason why I only use a 50-50 antifreeze mix, never straight water.
    By the way freeze plugs are a misnomer.
    They are not really freeze plugs although they will sometimes save a frozen block.
    They are actually core plugs.
  30. Toqwik
    Toqwik
