Technical This is what makes hot rodding so satisfying
Discussion in 'The Hokey Ass Message Board' started by willys36, Apr 3, 2024.
  1. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Here ya go for nails on the chalkboard effect!
  2. gene-koning
    gene-koning
    The last time I needed a lower radiator hose, the guys at my local parts store let me go back and look at their inventory. They only had about 10 radiator hoses in the house. I was lucky to find a hose with both ends the correct size. Then I cut up some tubing and welded it together to get the ends where they needed to be.
    Used to be able to get stainless kitchen drain pipe to cut up and weld together, but all of that you can find around here is plastic pipes and elbows now.
