This is why "NOT" to buy sight unseen..
Discussion in 'The Hokey Ass Message Board' started by flyinlow1000, Jan 16, 2012.
  1. Bigdaddyhemi
    Bigdaddyhemi
    Look on the bright side, at least there is a good frame to weld to. It could be a lot worse. I would say you are lucky in more ways than one. ;)
  2. dutch rudder
    dutch rudder
    from houston
    ding ding!
    easiest way is on the alignment machine. if the thrust is out, or you can get the front end to swing in caster/camber/toe, then you need to hack and whack.
  3. Wild Turkey
    Wild Turkey
    I wouldn't bet on that -- I don't think a 110v welder could make a mess that big:rolleyes:
    Seriously -- what was he doing wrong (okay, maybe it should be what WASN'T he doing wrong) too much heat for the stick size?
    I've welded enough to know that isn't good, but I'm wondering what was wrong.:confused:
  4. darkk
    darkk
    Well we know one thing, the guy can't weld worth a damn....the up side is you should only have a few hours grinding and welding. Provided the suspension is some where near where it's supposed to be.
  5. 76cam
    76cam
    Damn dirt dobbers!!!lol.. The plus side is it can be fixed.
  6. 76cam
    76cam
    So how about a picture of the whole car.
  7. Blue One
    Blue One
    from Alberta
    This was done by one of those types who say welding is easy, anyone can do it. :rolleyes:
    And welders make too much money :p
    Then they go and do that :D
  8. I thought it was a booger, but itssnot.
  9. Pop-Rodder
    Pop-Rodder
    In your honest opinion, does that snotty weld make the car not worth what you paid for it?
    Or.....
    For a minor amount of work will you have a car worth a lot more than you paid for it?
    Or...
    Is the value not important as long as it's what you want, and you're happy?
    Pick one..
  10. Boogars and bubble gum. eeiww!
    Take your time and make it right - enjoy all the satisfaction that comes from doing it yourself and doing it correctly!
  11. Spike!
    Spike!
    Grump Jenkins used to call them "bird ****" welds..usually refering to my welds..hahaha..don't worry, I only lasted six days.
    Spike
  12. alanwoodieman
    alanwoodieman
    a friend of mine would call that German welding "mess of ****"
  13. Abrasive Trader
    Abrasive Trader
    from Orange CA
    I do some off-roading and we call those "Trail Welds"!!! Gets your from point A to point B...maybe....
  14. 64ONEOFF
    64ONEOFF
    from Md.
    Man that is a shame, well the good thing is you seen it before you hit the streets. I have seen some shady stuff when it comes to welding. It could of really been ugly for ya. ATLEAST it can be fixed easy enough. Good luck...:)
  15. ronnieroadster
    ronnieroadster
    Ah yes bird **** welds how well I remember those days using a borrowed Sears 90 amp AC buzz box life was good indeed. Just grind them out and go to it again it will be corrected in no time.
  16. oldcarfart
    oldcarfart
    The bigger the glob, the better the job!!
  17. tommyd
    tommyd
    from South Indy
    Now THAT is a good at***ude to have. Most people want to blame anybody BUT themselves nowadays. Bet the fix will be easier with an at***ude like that.
  18. ebfabman
    ebfabman
    Four pages and not one picture of this "hot rod".....???
  19. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Looks like weld wasnt hot enough .Looks like a mig weld ,Arc over it at 130 ....
  20. Ebbsspeed
    Ebbsspeed
    If my penetration was that poor I'd never have had children.
  21. this just goes to show you that buying a used hotrod is not the way to go. No matter who built it, there will always be something wrong, somewhere. there should be some kind of law set in place that the original builder is required to keep the car he has built forever. That would eliminate what we see here, and what has been spoken about in other such threads. This car could have caused an accident while being hauled on a flatbed. If it was secured by the front end, those welds could have came loose over a severe bump and the car could have jumped off and dropped into traffic causing a m***ive traffic jamb, resulting in many injuries and the wreckage of millions of dollars of automobiles traveling our nations highways.
    the solution to this problem is simple. No selling of any used hotrod ever. When the original builder tires of it, he should be required to dismantel the car completely and sell off the parts he won't be needing for his next build.
  22. clubcoupe37
    clubcoupe37
    I bought my car sight unseen from a guy in NY. he had a lot of detailed pics..but that was all I went on. I got real lucky!! but I knew the car was just a starting point... I wouldn't say I would do it again though. the time i waited for it to show up was pretty stressful,lol
  23. VoodooTwin
    VoodooTwin
    from Noo Yawk
    I dunno if it's been said before, but I wouldn't recommend welding strut rod brackets onto the frame. Rather, fabricate brackets that bolt to the frame. The constant tension/compression action could crack the welds/tear the brackets off the frame. Just my worthless $0.02.
  24. Mopar Jack
    Mopar Jack
  25. 49F1Jeff
    49F1Jeff
    from Oregon
    Ya think? ;)
    :eek:
  26. My ex-wife can weld better than that and her entire experience was one high school cl*** ;)
    Spooky welding-good thing you lifted it up first.
  27. ebfabman
    ebfabman
    So you're never gonna show us your car???
  28. clockwork31
    clockwork31
    it all make sense, lesson learned.
  29. riv63
    riv63
    from Texas
    Looks like a flock of seagulls attacked it. I'm glad you found it in time to fix it before it wa a bigger problem.
  30. Brad54
    Brad54
    from Atl Ga
    There are two things in life where penetration is of the utmost importance... and welding is the other one.
    I'm of the opinion that welding is exactly like ***: get in a comfortable position, take your time, and get good penetration for pleasing results.
    And you'll be waaaay ahead of the game if you have someone with some experience teach you how to do it, rather than believing self-taught is good enough.
    -Brad
