Projects Thoughts on a 32 model B project
Discussion in 'Traditional Hot Rods' started by Brodie Bones, Nov 9, 2025.
  1. Brodie Bones
    Brodie Bones
    I have ‘32 model B roadster - original (frame, drivetrain, body) except for a fibergl*** rear trunk hatch. 59A flathead with a triple carb setup is the only mod.
    looking for thoughts from the forum on 3 topics to make this a driver:
    - steering
    - suspension
    - brakes
    I want to update the steering so its a little easier on the arms. Mustang, Vega , other? The rear buggy spring is bent and listing p***enger - I am thinking of staying with that setup with a new spring - thoughts on setup or additions? Brakes are original drums from 32 rebuilt…good thing I ride my bike a lot. Brake upgrades that don’t break the bank?
    Thanks for any thoughts on options
    BB
  2. ‘28 RPU
    ‘28 RPU
    There are many, many, guys on here that know far more than I do but I think that I can share my thoughts on your steering question. I have a ‘28 RPU and some years back I did the F-1 steering box conversion and if you want to maintain a stock appearance, that’s the way to go (in my opinion). That said, by Mustang, I ***ume that you are referring to a Mustang II? That is probably the way I would go however there is no way that you are going to keep anything remotely stock looking with a rack down there. I think that the best compromise is the Vega box. Cross steer is much better than side steer and with the Vega box there is no glaringly obvious “non stock” appearance.
    ekimneirbo likes this.
  3. redo32
    redo32
    Hi Brodie, I see you've been around for a few years, but this is your first post. Welcome to the conversation. First off, a '32 Model B is a four cylinder. Model 18 is a V8. Don't know what your serial numbers are, they will tell what the original engine was. Us '32 guys reserve Model B for stock four cylinders. If you want to keep a stock look as far as the steering an F-1 or F-100 box work with slight fitting and modification. @NealinCA makes an excellent new box that is top notch but might not fit your budget. Mustang boxes were used in the early 70's, requires welding a bracket on the bottom of the frame and uses the stock type drag link. In street rod applications it has been superseded by the cross steer Vega. More welding and changing the right spindle and as with the Mustang dealing with the column.
    What brakes are on it now? You said stock ch***is, should we ***ume they were upgraded to hyd? Boling Bros makes Lincoln brakes to upgrade the drum brakes. If you want to keep it traditional no need to upgrade to discs. Drums will stop a flathead powered light roadster.
    Suspension? Again, what have you got? I'm of the group that likes a good profile. If it sits right, it looks right. Dropped axle, reverse eye spring, upgrade shackles, tie rods and shocks. Same for the rear. It is rare to bend a spring. Check to see if the spring is settled in the frame pocket. '32's will normally lean to the driver's side. Guys will use a tapered shim between the spring and frame. Use a reverse eye spring to lower one inch.
    Algoma56 likes this.
  4. 38Chevy454
    38Chevy454
    As 28 RPU stated, the F-1 box is a common upgrade. However they are getting tougher to find, and cross steer is better. Ford went to cross steer later. Whether using the Vega box or a later Ford cross steerbox.
    Brakes the typical swap is use 37-41 spindles, with 40 style hydraulic brakes. Or get F-1 spindles and F-1 brakes or 53-56 F-100 brakes. Or any of the aftermarket solutions available. Rear just convert to hydraulic, your front brakes are much more important.
    Suspension just decide of you want lower or stock height. You can get reverse eye spring to lower, or spring with less arch. Do you have or want a dropped axle in front?
  5. krylon32
    krylon32
    from Nebraska
    Steering: Neal Jennings Converted Hudson style box. Retains the original style steering.
    Suspension: Clean up the original suspension, remove a few leaves to soften the ride and
    build the original shocks pr get the new Roto Phase shocks.
    Brakes: Convert to Boling Bros. Lincoln style drum brakes.
    Ain't many nearly original 32's left. Also get a Brookville steel deck lid.
  6. 3blapcam
    3blapcam
    F1, F100 or even early Ford cross steer all work fine. Mustang box will ugly up the car. That's no bueno. If you're gonna do a Vega, may as well go all in on a street rod and IFS the car. Major thumbs down.
    Dennis Lacy makes a killer bolt in hydraulic conversion kit. I don't recall his HAMB handle, but if you Google his name and '32 hydraulic conversion you'll find him. He's out of California. Any early Ford hydraulic brakes will bolt on. I think stock '32 spindles require some mods or spacer ring for them to index correctly. Rears bolt on. I think Dennis Lacy has those too. Those pushing Lincoln brakes aren't wrong, they're self adjusting, which makes them a great choice. Early Ford are a few bucks cheaper and work just as well. Occasionally they need adjusting, depends on the miles you drive them.
    Follow Krylon's advice on the springs & decklid.
    And then, Hot Rod along!
    3blap.
    Algoma56 and Kiwi 4d like this.
