Technical Thoughts on reusing front crank seal after pulling balancer?
Discussion in 'The Hokey Ass Message Board' started by 57JoeFoMoPar, Oct 29, 2021.
  1. 57JoeFoMoPar
    57JoeFoMoPar
    A few years ago I bought a brand new GM 350ci/290 hp crate engine for a project. I bought a **** balancer, installed it, and mocked everything up. Now two years later I'm getting into final ***embly and tore the engine down to clean it off, paint and clear it, re***emble it, and install it in the car for good. Obviously I pulled the balancer back off to paint the engine, but do I need to replace this seal? The engine has literally never ran. I just didn't know if this is one of those deals where once the balancer is on the seal is no good after. Of course I'd rather leave it, since I'd really rather not pull the timing cover off to press a new one in the right way.
    Thoughts on this one?
  2. BJR
    BJR
  3. bill gruendeman
    bill gruendeman
    I would run it with out replacing it, but I wouldn’t pull the cover off to press on a new on. That’s me right or wrong.
    427 sleeper and Bob Lowry like this.
  4. Bob Lowry
    Bob Lowry
    2X on both of the above...
    427 sleeper likes this.
  5. oldiron 440
    oldiron 440
    It's going to leak no matter what you do so I'd run it...
  6. 57JoeFoMoPar
    57JoeFoMoPar
    Ah c'mon man, I don't want to hear that kind of negativity haha.
  7. Ericnova72
    Ericnova72
    from Michigan
    It will be fine, heat cycles, vibration and friction are what kills it.
    Right now it is still no different than if it had sat in it's original box on the shelf.
    427 sleeper and ottoman like this.
  8. chargin03
    chargin03
  9. Beanscoot
    Beanscoot
    Put a bit of oil on the lip before reinstalling the balancer.
    Truckdoctor Andy likes this.
  10. 2OLD2FAST
    2OLD2FAST
    from illinois
    Take a minute & think how pissed you'll be if it leaks & how much of a h***le it is to replace after its in the car .........I think they're under $10........ & about 1/2 an hour to replace while its sitting on the stand .........
