Technical Thoughts on this chassis
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Oct 21, 2021.
  1. Johnny Gee
    Johnny Gee
    from Downey, Ca
    If the idea can hold up much heavier things why not.
  2. nochop
    nochop
    from norcal
    Depends on who welded it….me weld it….p***
    -Brent- and anthony myrick like this.
  3. kasselyn29
    kasselyn29
  4. Happydaze
    Happydaze
    I have a beautiful Ionia HRS built frame with belled holes in the boxing plates. But the boxing plates are not holed along the entire length as there are a variety of items fitted necessary to make a bare frame into a running vehicle. In fact I've had to most regrettably lose one hole on each side to accommodate further stuff - who needs a rear anti roll bar? Anyway, my point is the comprehensive relieving of the frame pictured will either make it virtually impossible to fit necessary components and / or without same being visible from the outside, which I can't imagine will have a good look. Cool for a non functional, show rod I'm sure but just because you can....
    Chris
    SR100 likes this.
  5. DDDenny
    That's some kind of funny!
    Baumi and Moriarity like this.
  6. dirt car
    dirt car
    from nebraska
    No weight reduction if all equal gauge, as what has been cut out was equally sleeved back in, but then on a positive note looks to be well crafted .
    VANDENPLAS likes this.
  7. williebill
    williebill
    Sibley should buy it, and build something cool with it.
    j hansen, loudbang and VANDENPLAS like this.
  8. A little goes a long way
  9. rusty rocket
    rusty rocket
  10. We called it Le fromage de suisse
    twenty8, Chavezk21, Just Gary and 2 others like this.
  11. A little overkill but could make a cool show rod or hot wheels inspired car. Maybe a drag inspired car?
    anthony myrick likes this.
  12. Stan Back
    Stan Back
    Wouldn't want it for a Bonneville roadster -- too many places to hide the salt.
    anthony myrick and VANDENPLAS like this.
  13. Budget36
    Budget36
    As mentioned the challenge would be all the crossmember and engine mounts.
  14. so true
  15. chevy57dude
    chevy57dude
    Usually, holes are ''added'' to reduce weight. This guy went the other way to look cool. Trying too hard.
    How about a poll on this thread? Don't know how to add that to a thread.
    My vote is ''uncool''..
    anthony myrick and Stan Back like this.
  16. Mike VV
    Mike VV
    from SoCal
    Only strong if it stays on the jack stands..!
    IF...ALL of the welds were PROPERLY done, it might stay together for a while.
    BUT, on one hand, it would most likely be pretty flexy. On the other hand, there's a LOT of weld to crack and break as flex joints.
    Maybe ONLY under a show only car.
    Mike
  17. warhorseracing
    warhorseracing
    from cameron wv
    For a trailer queen show car that has no guts in the engine transmission and rear end and is pushed everywhere it goes. OK. If you are into that. My concerns if it would ever be powered and driven. Stress cracks at each and every weld. Yes, tabs could be added to attach cross members. But. NO!
  18. BamaMav
    BamaMav
    from Berry, AL
    That's a special edition Wisconsin model frame. Engineered by Kraft Foods to showcase it's cheese products. Sadly, the tin termites ate the body before the rats could get to the cheesy frame....
    partsdawg, anthony myrick and Tman like this.
  19. dylan60
    dylan60
    from ny
    i drilled and sleeved that frame have a crossmember already made up for it.. i just never put it in i just lost interest in it. it weighs a ton compared to a stock frame . my plan was model A roadster quick change hemi. i'm sorry i offended the purists. but sometimes you have to build something other than a black roadster with a flathead lol
    XXL__, Baumi, Joe Blow and 16 others like this.
  20. mgtstumpy
    mgtstumpy
    Ned Ludd, anthony myrick and dylan60 like this.
  21. and it wasn’t posted as a dig.
    Honestly wanted to hear thoughts from some of the guys here with an engineering background.
    Holes have been drilled in **** since the black roadsters and flatheads:):)
  22. nochop
    nochop
    from norcal
  23. dylan60
    dylan60
    from ny
    I know weren’t in all honesty I think it’s kind of funny. I’m also a bit flattered that that pic made it to hamb
    Baumi, williebill, Happydaze and 3 others like this.
  24. milwscruffy
    milwscruffy
    Glad I'm not the one who has to paint it, that would be a real pain.
    dylan60 likes this.
  25. mgtstumpy
    mgtstumpy
    Belled (Dimpled or aviation style) holes would certainly add strength to the above frame (#52). A LOT of welding in OP with all the holes being sleeved over the length of that frame.
  26. Remember, most of the folks dissing it probably can't weld and drive a 4dr ****box. ;)
    While mine had half as many holes I found no issue getting good coverage. Sawhorse and engine stand as rotisserie
  27. Tear on the dotted line.
    Happydaze likes this.
  28. hotrodlane
    hotrodlane
    Being different is not always a good thing
  29. I’ve always like the look of the holes for the correct style build.
    Was planning to integrate something similar for an upcoming project.
    My questions would be what size hole per channel width does t take away strength.
    dylan60 likes this.
  30. I aim for visual cleanliness. On the one I posted it meant leaving a solid inch or more above and below the hole. That is 5" tubing so....3" holes. For the front crossmember the holes were functional, it had bungs on the backside for pipe fittings and worked as a transmission cooler.
