Technical Thoughts on this rear suspension setup
Discussion in 'The Hokey Ass Message Board' started by ratfink56, Mar 19, 2022.
  1. ratfink56
    ratfink56
  2. Budget36
    Budget36
    I would think shocks work better out by the wheels, but have no experience with them so far inboard
  3. Phil P
    Phil P
    I agree I wonder if there would be a lot of body roll with the mounting points so close together.
    Phil
  4. krylon32
    krylon32
    from Nebraska
    For lack of a better term the coil overs are mounted *** backwards. I've done a few ch***is and never seen that before.
  5. Backwards and looks weird too boot.
    2OLD2FAST and MMM1693 like this.
  6. gimpyshotrods
    gimpyshotrods
    Mounting your coil overs like that will encourage body roll, rather than discourage body roll.
    That needs to be cut apart and done over immediately.
    Mimilan, Tim, X38 and 3 others like this.
  7. gimpyshotrods
    gimpyshotrods
    Get new lower coil mounts, and mount them the same distance outboard of the vertical line drawn from the top mount as the current mounts are mounted in board. Well those on the axle and then cut off the ones that are on there now.
  8. ratfink56
    ratfink56
    Pic is from a for sale ad. I had not seen this before and thought it looked wrong. But I haven't seen everything yet.
  9. spanners
    spanners
    Looks like it was done for form rather than function.
    VANDENPLAS likes this.
  10. oldiron 440
    oldiron 440
    If the form was Dysfunction he nailed it!:)
  11. goldmountain
    goldmountain
    It depends on how much they are asking for the car. If it is cheap enough, it can be easily changed.
  12. twenty8
    twenty8
    The closer the spring (any spring) is mounted on the axle out towards the wheel the better. There seems to be more than enough space to have set it up correctly, yet it has been done so wrong............:eek:
    Motion ratio for a solid axle is usually taken as 1:1, but having the suspension arcing around such narrow mounting points will not do much to control body roll. Sea sick tablets might be in order.
    lothiandon1940 likes this.
  13. gnichols
    gnichols
    from Tampa, FL
    I think this arrangement lessens your spring's leverage on the axle. The wider it is spread, the more stable the car is. There is probably an official term for how far the spring's mounts are apart. Anyone?
  14. Looks totally counterproductive.
    gimpyshotrods likes this.
  15. fastcar1953
    fastcar1953
    Belongs in the mickey mouse repair thread.
  16. BamaMav
    BamaMav
    from Berry, AL
    Extremely weird looking.
    49ratfink, gimpyshotrods and Tman like this.
  17. Brian Penrod
    Brian Penrod
    Not optimal but it'll work.
  18. Read the above reply from Gimpy. This setup does the exact opposite of what you want a suspension to do.
  19. twenty8
    twenty8
    That's a very loose use of the phrase "it'll work"..............o_O
    49ratfink, 2OLD2FAST and VANDENPLAS like this.
  20. Anderson
    Anderson
    Holy ****. No.
    X38, VANDENPLAS, Tman and 3 others like this.
  21. Kind of like standing up with your legs crossed. Then some guy gives you a shove.
    clem, 49ratfink, kadillackid and 5 others like this.
  22. jaw22w
    jaw22w
    from Indiana
    Somebody had the blueprint upside down!
    clem, alanp561, 2Blue2 and 6 others like this.
  23. twenty8
    twenty8
    That's brilliant. If basic suspension theory was presented like that, more people would understand, and far less stupid **** would be done.........:D:D:D
    WalkerMD likes this.
  24. Mimilan
    Mimilan
    There are advantages of setups like that.....But not on a hotrod.
    I've seen this type of geometry work very well on Off Road vehicles that need relatively stiff straight line suspension [for jumps]
    blowby and Tman like this.
  25. Hollywood-East
    Hollywood-East
    Rite... Dyslexic comes to mind.
    2OLD2FAST likes this.
  26. blowby
    blowby
    from Nicasio Ca
    Buy it!
    seb fontana likes this.
  27. spanners
    spanners
    Yep, the wheels will go 'round so job done.
    49ratfink likes this.
  28. gimpyshotrods
    gimpyshotrods
    Depending on how well the front suspension is set up, and how heavy the engine and transmission is, this has the potential to be dangerous.
    Tman likes this.
  29. gconnsr
    gconnsr
    from AZ
    It has to be a clown car. The brake line looks like a 2 year old installed it and nobody in their right mind paints a rear axle white.
  30. Mimilan
    Mimilan
    With conventional wisdom you are 100% correct. But there are some innovative designs that go against the grain.
    Normally with laid down coil-overs , during body the outside spring becomes more perpendicular to the forces applied when it compresses more.
    This is the principle behind "Rising Rate Suspension" that McLaren introduced [except they used rockers arms]
    Honda also used these principles with their Pro-link
    I've seen the above style on an off-road racer where they needed a very stiff wheel rate for straight line jumps but needed it to have soft roll stiffness to prevent oversteer. [decreasing rate suspension]
    I've also seen a Left-Turn dirt car with only one rear coil-over . The Right Rear was totally removed.
    It had so much L/H weight bias, that the RR wasn't needed. The LR was moved inboard [so basically it was a "tripod" with no rear roll stiffness]
    All the weight jacking was done at the RF.
    That car had a lot of corner exit lift on the RH side by setting the links with a lot of "anti-squat"
    [The example the OP posted isn't any of these]
    It would be interesting seeing how that fibregl*** body stood up when that landed. [especially with a ladder frame and no roll cage]
    clem and twenty8 like this.
