Technical Thoughts on this rear suspension setup
Discussion in 'The Hokey Ass Message Board' started by ratfink56, Mar 19, 2022.
  1. choptop40
    choptop40
    im shocked...
    clem likes this.
  2. seb fontana
    seb fontana
    from ct
    Got to be foto shop, the car is higher than the ramp launch angle.. I do wonder the landing though..
  3. blowby
    blowby
    from Nicasio Ca
    Joie Chitwood was a pretty famous daredevil, my guess is it's real.
    49ratfink and Dick Stevens like this.
  4. 2OLD2FAST
    2OLD2FAST
    from illinois
    WTF does the color of the axle have to do with anything ( mines white )
    Dick Stevens, alanp561 and WalkerMD like this.
  5. choptop40
    choptop40
    white rear axles look amazing....
    WalkerMD, RICH B and 2OLD2FAST like this.
  6. Kiwi 4d
    Kiwi 4d
    Is that a panhard bar above the LH shock. ***uming this is a LHD car isn’t it also mounted the wrong end to the frame and axle? Does it make a difference on the rear?
    X38 likes this.
  7. Phil P
    Phil P
    It looks like a panhard rod to me, I didn't know it made any difference which side was which.
    Phil
  8. blue 49
    blue 49
    from Iowa
    I hope it doesn't make a lot of torque. Just looks like front hairpins locating the axle.
    Gary
    X38 likes this.
  9. X38
    X38
    Frame mount for panhard should always be same side as the steering box.
  10. ronzmtrwrx
    ronzmtrwrx
    I did not know that. Why ?
  11. X38
    X38
    So that the panhard and tie rod move in similar arcs and don't jack against each other with suspension movement.
    Bandit Billy and alanp561 like this.
  12. Dedsoto
    Dedsoto
    from Australia
    Doesn't appear to have a tailshaft so shouldn't be a problem :D
    twenty8 likes this.
  13. ronzmtrwrx
    ronzmtrwrx
    Is that for a cross steering setup only, or does that apply to side steer setups?
  14. X38
    X38
    That would be for cross steering.
  15. ronzmtrwrx
    ronzmtrwrx
    I figured. Makes sense, I just never thought about that. Thanks.
  16. Zuffen
    Zuffen
    from Sydney
    I'm at a loss why there is a difference as to what side of the vehicle a rear Panhard works from. Would that make Ford's Watts Linkage wrong?
    I will say the Panhard should be as horizontal as possible when the vehicle is at ride height to stop excessive sideways travel of the axle on bumps. This one sure isn't
  17. X38
    X38
    No. It's a different animal.
  18. Mimilan
    Mimilan
    @Zuffen @X38
    In L/H turn oval racing all the idiots mounted the panhard on the L/H axle and R/H frame so the Panhard was under tension during cornering. [because it was stronger or didn't bend blah blah!]
    But all the smart guys mounted the panhard on the L/H frame and R/H axle so the Panhard was under compression during cornering.
    Then they had adjustable heights at both ends [multiple mounting holes] so they could lift or lower the panhard to raise or lower the Roll Centre Height,
    AND they would also alter the angle downwards from horizontal to increase side bite onto the R/R tyre [from lateral acceleration]
    A wedged and staggered dirt car would have the Panhard under tension on the front axle and compression on the rear axle.
    This helped the L/F "grab air" and transfer weight diagonally to the R/R on corner exit.
    The Panhard became obsolete on the rear when they started using a Jacob's ladder which increased side bite with body roll
    RICH B likes this.
  19. 49ratfink
    49ratfink
    looks like there is a few miles on it. I think I would be more concerned about the welds that look like they have very limited penetration than the funky coil overs
