Technical Thread sealer
Discussion in 'The Hokey Ass Message Board' started by silent rick, Jan 28, 2026 at 9:53 AM.
  1. silent rick
    silent rick
    I believe hemi intake and exhaust manifold or header bolts go into the water jacket. what is the best sealer to use on the bolt threads?
    same sealer on both? does it need to be high temp? will the use of thread sealer affect torque ratings? what should I use
    Sharpone, Just Gary and chryslerfan55 like this.
  2. Sporty45
    Sporty45
  3. lake_harley
    lake_harley
    Using Teflon pipe dope with PTFE (I think those are letters) is what was recommended by my engine machinist friend who is built many race engines. A particular pipe dope I'm talking about comes in a tube and when you squirt it out it has a little bit of a granular look to it. I've used it on numerous engines and never had a problem. I squirt out some on threads of the bolt and use my finger to smear it into the threads. Mayby I'm just a slacker but I just torque things like I normally would.
    Lynn
    Just Gary and firstinsteele like this.
  4. silent rick
    silent rick
    I've always used permatex Teflon thread sealer in a small orange squeeze tube.
    I intend to use it unless someone says there's something better
    SS327 and Just Gary like this.
  5. chevyfordman
    chevyfordman
    Blue Monster always works
    lilCowboy likes this.
  6. lilCowboy
    lilCowboy
    that's what I started using per a tip from someone on some google search, and I'll never use regular teflon tape again.
  7. Just Gary
    Just Gary
    On my 354, the two front valve cover bolts also go into the water jacket. A bit of black RTV and good gaskets seem to keep everything where it belongs.
    Sporty45, seb fontana and silent rick like this.
  8. seb fontana
    seb fontana
    from ct
    Many years ago Permatex #2 was all I used. Used to be able to glue a Flathead together pretty good!
    RMR&C, CSPIDY, Sporty45 and 2 others like this.
  9. Sharpone
    Sharpone
    That’s what I use, works good. I just torque to spec. Using #2 may affect the torque reading slightly but not sure, I’ve never had a leak.
    Dan
    Sporty45 and Just Gary like this.
  10. RodStRace
    RodStRace
    There has been a lot of advancements in sealers over the past couple decades, just like the paints that are called out for being expensive.
    The old faithful #2 non-hardening would be the traditional choice.
    RTV ends up too solid for my taste.
    Teflon tape or liquid would be a good choice.
    I like to ask the folks that make the stuff, NOT the marketing dept, the tech dept. You have the big players who each probably make a dozen or more that will work. Example, Permatex
    https://www.permatex.com/product-category/thread-compounds/thread-sealants/
  11. SS327
    SS327
    Permatex liquid Teflon in a tube.
    Just Gary likes this.
  12. mohr hp
    mohr hp
    from Georgia
    Gotta say it, Gary, that thing is gorgeous!
    hammer-time, Just Gary and Sharpone like this.
