Three-On-The-Tree Shifter Ideas?
Discussion in 'The Hokey Ass Message Board' started by Glass_Packs, Jan 23, 2009.
  1. Glass_Packs
    Glass_Packs
    I know this has been discussed before and I have searched through the archives, but nothing really grabbed me for what I should use as a shifter handle for a three-on-the-tree transmission. What have you guys used for on the column shifter handles? One idea that I found in another thread is using the handle off a screwdriver.
    Thanks!
    Tom - Gl***_Packs
  2. milorat
    milorat
    I like that idea,or maybe a whole long screwdriver.
  3. hotrod-Linkin
    hotrod-Linkin
    beer tap handles..same as floor shifter.
  4. bobwop
    bobwop
    from Arley, AL
    the original handle!
  5. ckemp03
    ckemp03
    from Warwick RI
    I use a de-militarized ma duece (.50 cal) shell. Watch your head when working under the dash.
  6. solid
    solid
    You dont see many knobs, other than factory on three on the tree cars. How about a mid sized crescent wrench welded to a nut theaded on the original shaft. Maybe a old stainless steele meat grinder handle, or a old hand turned bench grinder handle, it would be a good length, and have roller bearings in it. Like a spinner knob sorta.it would kinda look factory.
  7. GassersGarage
    GassersGarage
    I saw a door knob used on a shifter last weekend.
  8. Glass_Packs
    Glass_Packs
    Just a quick question. I've looking into the screwdriver idea and the possibility of machining the same shape out of the same material (cellulose acetate + plasticizer?). Does anyone know if there's a company that sells a block of this material used for screwdriver? I'm looking for sometype of material in a transparent amber color.
    Thanks!
    Tom - Gl***_Packs
  9. Little Wing
    Little Wing
    from Northeast
    What ever you use,,keep the weight the same as the original,,to heavy and you WILL run into problems
  10. Glass_Packs
    Glass_Packs
    Thanks for the tip Satanherself! The handle of the screwdriver is a little bit heavier than the current cracked knob on the column shifter, but I think that it's light enough to not pop out of gear. Plus if it is too heavy, I have a nice original shifter I could replace it with.
    Thanks!
    Tom - Gl***_Packs
  11. DRUGASM
    DRUGASM
    skateboard wheel
  12. AugustIII
    AugustIII
    from Maryland
    "beer tap handles"
    I absolutely love that idea. I had always thought of using a screwdriver handle...but your idea is way better.
  13. 64krusty
    64krusty
    I tried an 8 ball,looked cool but was too heavy.
  14. lakes modified
    lakes modified
    Get the ones that have various spiders & bugs in them.The guy in NY who makes them, does a super job of them. I have one with a big spider in it.It's on top of my 39 trans lever.
  15. Brad54
    Brad54
    from Atl Ga
    How 'bout making one about 4-feet long, so that it runs the entire length of the dash. Make it out of light weight aluminum, so it isn't too heavy, and then cap the far end with an Iron Cross, or maybe a skull.
    If you're doing it on an open car, like a roadster or something, you could make it long enough to stick out past the door, and cap it with a rear view mirror. Design it so it actually rests on the door when in 3rd gear, so weight isn't as much of a consideration. Your hand would support it in Reverse, 1st and 2nd, right?
    I think that'd be a lot cooler than the lame-*** stock shifter handle dressed up with a period-correct colored gl***, plastic or chromed knob. I mean, if you're going to scream for attention, then SCREAM for it!
    -Brad
  16. RichG
    RichG
    I used a broken off pipe wrench, I think it was a 14", it was aluminum too, not very heavy. Off the subject, the shifter in my '27 is going to be the broken off handle of an aluminum pipe wrench, but this one is about 40" long...
  17. then you could paint your car flat black with red rims a fit a tractor grill,dont forget the fake bullet holes and spider webs;)
    but seriousley I second the skateboard wheel idea
  18. Mr48chev
    Why not laminate your own out of some lucite either clear and translucent or maybe solid colors and shape it into a nice looking shift knob.
    Or do it with different shades of hardwood. Or a solid piece of hardwood or block of plastic.
