Technical Three Point Seat belts
Discussion in 'The Hokey Ass Message Board' started by seb fontana, Sep 4, 2022.
  1. seb fontana
    seb fontana
    from ct
  2. kabinenroller
    kabinenroller
    Muffler clamps are for mufflers not seat belts. I would weld a substantial tab to the roll bar and attach the top mount to that. Make sure you install the tab at the correct height in relationship to the seat.
    Almostdone, SEAAIRE354 and X38 like this.
  3. G-son
    G-son
    from Sweden
    ***uming I'm using this right...
    Impact Force Calculator - Calculate the impact force in a collision (gigacalculator.com)
    A 200lb person travelling at 30mph experience a stop over a total distance of 1yd (seems somewhat resonable for how much a car can crumple) makes a max force of 17.8kN, we'll round that off to 1.7 metric tons or 3500lb.
    Would you hang your entire 3500lb car from one of those clamps?
    This was at low 30mph, higher speed means bigger forces.
  4. squirrel
    weld on a tab and use a 7/16" bolt, perhaps?
    fauj, SEAAIRE354 and Tow Truck Tom like this.
  5. gene-koning
    gene-koning
    The bottom roll bar mounting bolt would probably be OK for the recoil mount, since both are bolted to the floor pan. But I would rather see the upper mount be in the door post, or body structure rather than hose clamped to a bolted in roll bar.
    I have serious doubts that clamp pictured would have the capacity to keep the belt mount attached to the roll bar in a crash, then there is the fact the seat isn't attached to the bar.
    If the seat base was attached to the roll bar, and the belt mounting bracket was welded to the roll bar, maybe that would p*** for me.
    If the seat and the roll bar are not attached to each other, there is a possibility the bar and the seat may move in different directions in a crash. There are reasons you do not bolt a seat belt to the frame on a car, but you bolt it to the floor pan beside the seat.
    All that said, a 3 point belt that won't pull free of the vehicle in a crash, is probably a lot safer then just a lap belt. My opinion is worth as much as you paid for it.
    vtx1800 likes this.
  6. seb fontana
    seb fontana
    from ct
  7. Ned Ludd
    Ned Ludd
    Useful calculator, thanks!
    There are a number of factors which determine whether that clamp would be suitable for the job, and what it's meant for isn't one of them. Valid factors would include the cross-sectional area of the strap and the tensile strength of the material. The ad Seb linked to gives a cross-sectional area of .0875 square inches, but it doesn't mention a material grade. Adjusting a typical stainless tensile strength value for impact and a safety factor suggests a working figure of around 26 000psi, which means that the clamp would practically be good for about 2275lbs in the proposed application.
    @G-son rightly points out that his calculated figure of 3500lbs ***umes a very low speed. It nevertheless makes no sense to design for a tensile strength vastly greater than that of the seat belt which is to be attached to the clamp. That is known: seat belt webbing is rated at around 5000lbs, though it might carry somewhat more in actual fact. It points to the clamp being at best less than half as strong as it should be.
    So: this muffler clamp would be wholly inadequate for the proposed purpose, but a different, heavier muffler clamp might be perfectly suitable.
    Spoggie and G-son like this.
  8. bobss396
    bobss396
  9. oldolds
    oldolds
    What does N.H.R.A. want for belt mounting points with a roll bar? That would be the "gold standard" for how a seat belt should be mounted. I would look at the specs for what they want of stock bodied cars that run just fast enough where they are required. 10.00 et. I believe.
    They might be for a 5 point belt, but it will still point you in the right direction.
    G-son likes this.
  10. flatout51
    flatout51
    If you're willing to spend $230 on your belt why would you go with a cheap exhaust clamp to hold it? Weld a tab to the roll cage and be safe. Might as well keep just a lap belt if the top is secured with that clamp.
    Spoggie and Cosmo49 like this.
  11. Joe H
    Joe H
    If this is race car, the roll cage should be NHRA approved and five point belts already installed, its mandatory. If this is just a bolt in cage never to be raced, it could be as easy as drilling a hole through the tube and bolting the upper mount to it, this would be far stronger then a u-bolt type mount, but neither of which will p*** any type of tech inspections. I would bet any type of tab mount would get looked at pretty hard as well.
    Post some pictures of the area, the upper body mount would be the best bet, it would spread the load out along the the whole upper structure leaving the cage as is.
    An easier option would be to use four or five point belts bolted to the floor, run the shoulder belts over the cage cross bar and down to the floor.
    https://www.wescoperformance.com/3lap3shinwra.html
    https://www.summitracing.com/parts/csu-44001b
  12. mohr hp
    mohr hp
    from Georgia
    Know that by law, Race Type harnesses (which typically have to be re-webbed or replaced every few years) are illegal on the roads in the US. Maybe no one will ever check or question them. Meanwhile, you can use 60 year old junkyard belts forever on the streets. I just went through this on my latest project, spent 45 minutes in the boneyard 'til I found a set I like (Dodge Dakota back seat) and I got them for $25.
    seb fontana likes this.
  13. squirrel
    Uh....which law? and when installed in what car? Sounds like a blanket statement that might not fit all situations.
  14. seb fontana
    seb fontana
    from ct
    The law that says arms aren't long enough to reach dashboard?:rolleyes:
  15. bangngears
    bangngears
    from ofallon mo
    Shoulder harnesses save you, lap belts insure a pretty corpse. With a lap you are still gonna hit the steering wheel
  16. seb fontana
    seb fontana
    from ct
    upload_2022-9-5_15-58-37.jpeg Best angle I could find. I did try shoulder harness but quickly found out I couldn't reach the ing switch when buckled in. Only reason for the roll bar was because of gl*** body parts, not ET. I have to measure the relationship of B pillar roll bar and seat. Seat maybe too far back for B pillar, Roll bar maybe wide enough to keep belt away from neck when buckled.
  17. Mr48chev
    NO DOT approval tag. The kit car guys fight that one a lot. Even though the car has a 4 point harness that can p*** tech at any drag strip in the country and p*** land speed tech forr the cl*** the car would run in including having do***entation that the webbing is up to date it won't p*** inspection for highway beause it doesn't have the DOT tag.
  18. Mr48chev
    From where I sit it looks like having the mount point on that roll bar might be a good way to snap your neck with the belt, meaning that the position is going to put the point where the belt crosses the seat inboard of the seam that is 2 inches or more in. It won't go across your shoulder and chest it will go around you neck and cross your chest at a steep angle.
    The proper place is on the door post at the correct height using the plate provided in the kit and having it securely fastened. Sebs shoebox (2).jpg juliaano seat belt (2).jpg
    Spoggie and seb fontana like this.
  19. 48 Indian Rag
    48 Indian Rag
    from conn
    You live in Ct call or look up Juliano's in Ellington on their website they have a bunch of ways to set up your seat belts with good safe hardware, if your gonna do something safety related do it right
  20. squirrel
    So....that might apply to a car that's subject to a state inspection? But not my cars, since I live in Arizona....we don't have that safety inspection foolishness here. The guy who brought it up, made it sound like you can't drive a car in the US without having a DOT approved seat belt in the car.
  21. seb fontana
    seb fontana
    from ct
    Isn't it federal like sealed beams?
  22. Jalopy Joker
    Jalopy Joker
    if you have a roll bar there should be a cross brace behind front seat(s). then you should utilize that bar to install 4 point seat belts, not 3 point. there are some aftermarket cross braces available for cars without roll bar.
    Spoggie likes this.
  23. seb fontana
    seb fontana
    from ct
    Like I said in previous post: with a 4 pt I can't reach the Ing switch...
  24. Jalopy Joker
    Jalopy Joker
    sounds like you need to build a console, or?, that places ignition switch to a place that you can reach - easier to do than repairing your body in an accident with improper safety equipment
  25. seb fontana
    seb fontana
    from ct
    Post 6, 16, 18. I hate to get into the B pillar as I really don't think there is that much material there but if all that know insist there is then thats it. Was in Juliano's web site last week but couldn't find any thing other than a PU truck install that had factory B pillar mount; was looking for some install like in mid fiftys cars.
  26. seb fontana
    seb fontana
    from ct
    The AC knobs are there.. :rolleyes:
    Jet96 likes this.
  27. Jalopy Joker
    Jalopy Joker
  28. seb fontana
    seb fontana
    from ct
    I was kidding.. Post #18 looks like what I will do.
  29. greybeard360
    greybeard360
    You won't find info on how shoulder belts were installed in cars in the 50's because that didn't start until the late 60's. Most of the time those belts attached to the roof above the quarter window or rear door.
    Do it simple and just weld a tab to the roll bar.
    Crazy Steve likes this.
  30. seb fontana
    seb fontana
    from ct
    Sheesh.. Post #18
