Technical Three speed problem
Discussion in 'Traditional Hot Rods' started by soonrodder, Apr 30, 2022.
  1. soonrodder
    soonrodder
    from germany
    Hi all,
    I was looking for an answer, but could not find it, so here is the stupid thing which happened to me.
    I am building an AV8 Roadster actually.
    When I mounted my floor, I was sticking the shifter into the transmission again. But as it looks in a wrong way. The gears are no mire changeable now. I tried different positions, but it does nor move out of the gear. It was easy to change before.
    Which mistake did I do and are there any suggestions to solve this problem without opening the transmission or dis***emble the shift tower? Thank you for any help
  2. alchemy
    alchemy
    Make sure the shift forks are in the proper grooves in the sliding syncros.
