Hot Rods Throttle "Blip" Backfire...Why?
Discussion in 'The Hokey Ass Message Board' started by Deyomatic, Oct 30, 2023.
  1. Deyomatic
    Deyomatic
    from CT
    What causes a backfire through the carb when you try to "blip" or "rev match" while downshifting? Cruising along, shift from third to second, tap the throttle before releasing the clutch and "POP..." I'm pretty sure it's through the carb. Lean? Rich? Been chasing it for awhile.
    Holley 600 (1850-3).
    Thanks.
    Google and YouTube have been ZERO help.
  2. flamedabone
    flamedabone
    Usually, a carb pop is a lean condition or not enough timing at that point in the rpm sweep, but it could be a bunch of things. What are your initial and total timing numbers?
    -Abone.
    gimpyshotrods likes this.
  3. seb fontana
    seb fontana
    from ct
    First thing I would do is check compression, bad intake valve will do that.
    Desoto291Hemi likes this.
  4. pprather
    pprather
    Are header gaskets well sealed to the heads?
    427 sleeper likes this.
  5. Deyomatic
    Deyomatic
    from CT
    I can't imagine it's a bad valve. Everything moves just fine when I re-checked the lash a few months ago, and it runs great. I think it's more of a timing/ carb issue... Seemed to get better when I jetted up last time.
    I think the exhaust manifolds/gaskets are good and snug.
    I probably should check the intake, now that I'm thinking about it.
    Total timing is about 37, if I recall. I never bothered checking the initial. Seems better if I rev it up "slower" rather than just stabbing the throttle.
  6. inthweedz
    inthweedz
    I would check the accelerator pump operation, it's there to richen up the mixture when the throttle is given a quick blip, or opened quickly while driving, otherwise the ''lean mix'' (excess air) ****ed in on opening will cause a backfire out the carb..
  7. RodStRace
    RodStRace
  8. Marty Strode
    Marty Strode
    Good place to start.
    48fordor likes this.
  9. Bandit Billy
    Bandit Billy
    Power valve. My Olds eats them for breakfast after a winter of storage. One backfire and it's time to tear the front bowl off and replace the "blow proof" power valve. I stock them like bacon strips.
  10. I'm no stranger to a blown power valve in a Holley, but a bad power valve will make it too rich rather than too lean. No new information here I know, but on deceleration, shifting from third down to second could result in too much un-burned fuel in the exhaust and cause it to backfire.
  11. 2OLD2FAST
    2OLD2FAST
    from illinois
    Bandit Billy likes this.
  12. Ned Ludd
    Ned Ludd
    Air leak between carb and head.
  13. Deyomatic
    Deyomatic
    from CT
    Re-torqued the intake bolts today and the ones in the "middle" (Y-Block) required a little more to get up to 25 lb/ft.
    Also ordered the next size up on the accelerator pump discharge nozzle. Fingers crossed.
    Thanks gents.
  14. Bandit Billy
    Bandit Billy
    I tired the no blow valves. They blew. I have actually had this one in for over two years now. Running clear fuel seems to help.
  15. 2OLD2FAST
    2OLD2FAST
    from illinois
    Never heard of a" no blow valve" ?
  16. 427 sleeper
    427 sleeper
    I thought the blow out prevention went in the base plate, and the valve's were the same...
    2OLD2FAST and lumpy 63 like this.
  17. 2OLD2FAST
    2OLD2FAST
    from illinois
    Exactly !
