I am looking for some help with my throttle cable for my 1927 T lakes modified. I have used the pedal from a 39 with the 1/4" ball on the end. On the holly carb I have a 1/4" ball also. The cable itself will be quite short....ie about 12". Does anyone know of anybody that makes to order?
If you want a bolt on, then you're probably out of luck. If you don't mind doing a little fabrication you could remove the pedal and rework the end so it has a hole to accept an aftermarket universal cable assembly like Spectre or Lokar.
