Technical throttle linkage
Discussion in 'Traditional Hot Rods' started by dirt t, Nov 11, 2013.
  1. dirt t
    dirt t
    I have some questions on throttle linkage or gas pedal travel .
    see the attached graph and the bottom is the carb linkage travel for idle to wot.(Wide open throttle). Is a one to one ratio ok or will it be too much throttle too fast. There is a 3" and 4" which will slow down the travel ratio of pedal to wot. What is acceptable. The one to one would best for me as I do not have a lot of room for pedal travel.
    Thank You for your time .
    Terry aka dirt t
  2. dirt t
    dirt t
    Forgot graph sorry.
  3. i would think that 3-5/8" travel from idle to WOT is fine
    what does your daily driver have?
  4. 1971BB427
    1971BB427
    from Oregon
    One to one is fine, and in some cases I go less if I'm working with lots of HP. I've got about 1.5 to 1 on my Falcon with the higher HP, but 1 to 1 on my Austin's 327.
  5. classic gary
    classic gary
    from an experience:
    '56 chevy 210, stock pedal linkage all solid, no cable, on the other end was a Holley throttle body F.I. Put the stuff together and the car ran/drove fine. BUT, from a suggestion from someone, I lengthened the arm at the throttle body. Made the car MUCH easier to drive and the MPG went up. I've got no idea of the ratio's. Just a tid-bit from my experience.
  6. dirt t
    dirt t
    Did it still give you full throttle?
  7. classic gary
    classic gary
    Yup, there was enough travel, on both ends.
  8. fordor41
    fordor41
    I switched carbs on my '41 and lever on the new carb was shorter and gave a quicker pedal response but wasn't hard to get used to.
  9. tfeverfred
    tfeverfred
    I think just about every setup is different. It depends on the carb, linkage and pedal ***embly, and everyone is different. In my T Bucket, whether it was a cable or the mechanical linkage I have now, I set the carb at WOT and adjusted/measured my setup from there. I thijnk I have 4" of pedal travel, but that's fine for me. I also use a soft spring, so I guess it's a "hair trigger", but again, I like it that way.
    Just measure and adjust to find out what works for you. That's a nice diagram, but way to much thought on something simple.
