Thumpr cams-any input on SBC use?
Discussion in 'The Hokey Ass Message Board' started by Groucho, Jan 21, 2014.
  1. verno30
    verno30
    Agree 100%. I have used several Summit's as well with success.
  2. verno30
    verno30
    I would not suggest a Thumpr on a stock SBC (like the OP suggested he has)
    I have a Roller Big Mutha Thumpr for my SBC. What Comp suggested to me were 2 key points.
    #1 Maximum compression. These cams love compression as much of it bleeds off. 10.5 is not out of line. Easily 2 full points over the average stock SBC.
    #2 Maximum timing. These cams rely on a significant amount of ignition timing. Advance the distributor until it "pings" then back it off 2 degrees. Comp's words, not mine. I will say, I have always had good luck with Comp and believe I get the no ******** answer when I call. FWIW.
  3. xhotrodder
    xhotrodder
    Sounds great, but it also sounds like it is about ready to die unless you keep revving it. I had a RV cam in a .30 over 305, with a Edelbrock 4 barrel & intake, and block hugger headers. I also used a stock torque Converter. I used MEGS exhaust tips, on a dual exhaust set-up, and got a nice little rumble from the exhaust, good idle, and good gas mileage. It had a 3.08 geared rearend. I was very pleased with the sound and performance.
  4. 1971BB427
    1971BB427
    from Oregon
    That really depends on which Thumor is installed. The lower level I posted specs for is a very good cam to put in a stock 350.
  5. tjet
    tjet
    That's why I was asking about the vacuum advance. If you hook it up to a full-time port, you will pull max advance at idle which will smooth it out a little. He would need to use a special vacuum advance can though - one that pulls with a weak signal. On my small cap delco, I use a B-28 can. It's what they used on 65-66 fuelie vettes. The throttle response will be snappier.
    Here's a good read
    http://www.corvette-restoration.com/resources/technical_papers/Vac_Adv_Spec.pdf
  6. hoop98
    hoop98
    from Texas
    The 12-600-4 Thumpr has a very advanced (102) intake, but it is a 279 intake, the intake closes at 63 (.006). That means an iron headed 350 will want to be in the 9.5 -9.9 static range. Also because of the high (77 degrees ) overlap the carburetion and advance curves will be critical to have acceptable part throttle. You will definitely want a Vacuum advance and a have the mechanical in early.
    The B-28 canister can be found as:
    NAPA/Echlin VC-1810
    Niehoff DR-305
    Borg-Warner V329
    BWD V329
    Standard Motor Products VC-177
    Standard Motor Products Hygrade VC177
  7. Neat car!
    For some reason that sounds odd to me,
    Maybe it's just recording quality.
    Hard to describe sound and ****ogies ****
    But it's like out of rhythm when its your favorite song and the drummer is 1/2 a count off.
  8. jdubbya
    jdubbya
    Sorry, been away from the computer for a couple days. It was running a vacuum advance at the time of the video. I have since changed, and it runs like a champ. The video was taken the day after its initial run. It took some tuning, but it runs great now. Its a little cold for a new video update right now though. hahaha!
  9. tjet
    tjet
    I've searched, but the only place that still sells the B-28 is Autozone.
    The p/n you want is DV1810. It's around $14 ea
    Don't buy the V329 on ebay for $50
    http://www.autozone.com/autozone/parts/_/N-93xnh?itemIdentifier=118067_0_0_
  10. hoop98
    hoop98
    from Texas
    All of the part numbers above get you a B28 Can.
    Here is a pic of the SMP VC-177 See the B28?
    From the Corvette Forums
    http://www.amazon.com/Airtex-Distrib.../dp/B000C1ES7I
    Alternate Part Numbers:
    NAPA/Echlin VC-1810
    Niehoff DR-305
    Borg-Warner V329
    BWD V329
    AC/Delco part number D1312C
    GM part number is 88924985
    Wells DV1810
  11. tjet
    tjet
  12. hoop98
    hoop98
    from Texas
    The SMP-VC177 at Summitt has B28 stamped on it.
    I havn't tried the AC or GM numbers, they are interchange numbers.
    The SMP looks available.
    The Airtex/Wells is available many places.
  13. tjet
    tjet
    Hey thanks for the great info
  14. hoop98
    hoop98
    from Texas
    just sharing what i read!
  15. 66tintop
    66tintop
    from Canada
    Using va***n advance does work for sure, it sure helped the idle, still these cams will drive u fugly crazy trying to tune them for perfect drivability , I wouldn't put another one in any engine period , strictly a parking lot , rumpty rump pos cam . I would recommend anything but a thumper cam !
