Technical tie rod end question
Discussion in 'Traditional Hot Rods' started by ned5049, Apr 27, 2019.
  1. ned5049
    ned5049
    Question. 1932 Chevy ball and socket rod ends. Can these be drilled out and tapered to fit Ford type tie rod ends? Has anyone used these ball and socket ends ? Thanks in advance for any advice. 20190427_184313.jpg 20190427_184308.jpg
  2. I run them on my 33. they work fine once restored.
    I would think there would not be a problem having the end of the arm machines for a tapered end.
  3. rusty valley
    rusty valley
    sure looks the same size as ford stuff, if so, you can buy a new ball, and the rebuild parts pretty cheap. to drill it out and switch to modern stuff would be a breeze too. i think speedway sells the tapered reamer. or you cut the ball off and drill it for the new weld in ball from brattons model a parts
