Hot Rods Tie Rod - special one needed
Discussion in 'The Hokey Ass Message Board' started by guy1unico, Sep 2, 2023.
  1. guy1unico
    guy1unico
    My friend has a 59 AMC wagon. The car has a 62 or 63 motor and the oil pan sits in the way of the tie rod. Does anyone possibly prefab a tie rod that would go under his oil pan to the other side?
    Thank you
  2. alchemy
    alchemy
    Big market for ’59 AMC wagon hot rod parts! o_O
  3. guy1unico
    guy1unico
    I'm not looking here for an AMC wagon specific tie rod. Who makes custom tie rods?
  4. Just search "dropped tie rod ends" Jeep, Willys and others used them . Online or here, we have discussed them MANY times
  5. RICH B
    RICH B
    Just figure out the drop needed, fabricate one out of plate and tube, weld it to the stock tie rod, cut out the original center, and you have a dropped tie rod just like was done in the old days when putting in a front sump mill in a '49 up Ford.
  6. goldmountain
    goldmountain
    How about looking for the correct oil pan?
  7. guy1unico
    guy1unico
    All good advice ill go from here.
    Thank you
  8. continentaljohn
    continentaljohn
    I would modify the oil pan . As early nova II used a tierod that went thru the oil pan when you had a sbc installed
