Technical Tig brazing
Discussion in 'Traditional Hot Rods' started by Kingscustom, May 27, 2022.
  1. Kingscustom
    Kingscustom
    Hello guys new member with quit a bit of welding skills in tig and mig but zero in brazing. I picked up a 24 model T that I have found some holes in under old bondo. I have been reading that brazing is bad because of the flux and fillers and paint not wanting to stick to it, I'm wondering what the opion is for tig brazing with silicon bronze rod or is there a better option. My other thought was to use a copper backing and just tig the holes closed with ER70S2 filler rod . Thanks for any input
  2. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I have TIG brazed with silicon bronze rod in a non-stressed application fixing a deuce quarter panel. Its a little tough to keep the rod from dripping off before the base metal is hot enough to absorb the rod. It does significantly reduce distortion.
  3. Kingscustom
    Kingscustom
    Cool good info, I'm thinking i can pre heat with propane torch then just get after it to keep the filler from dripping off because the base metal isn't hot enough
  4. gimpyshotrods
    gimpyshotrods
    I do it all the time. It's no big trick.
    You use a much lower amperage than welding, so the risk of distortion is far lower.
    The issues with adhesion with brazing are not from the bonding material, but the failure to remove all of the flux.
  5. 6sally6
    6sally6
    One weldor to another.....don't try to re-invent the wheel.
    Just get a piece of copper (or thick Alum.) and weld the holes up.
    Prolly be stronger and less headache than " learning" how to fill a hole with a new technique and strange weld material to fill a hole with weaker material! IMHO
    6sally6
  6. Kingscustom
    Kingscustom
    So with Tig that sounds like the way to go. All argon zero flux . I wanted to get some opions before I got after it, thanks
    Kroombit likes this.
  7. badshifter
    badshifter
    There is nothing wrong with brazing, as you said it’s the flux that’s the problem. Properly clean braze is fine. No issues with silicone bronze tig. Just clean well after any process.
    Kingscustom likes this.
  8. gene-koning
    gene-koning
    So the question is, if you have a TIG, and the skills to use it, why on earth would you want to fix a hole in sheet metal by brazing? The brazing process has enough issues connected with it, why would you even bother when you already posses a much better process? Coming up with sheet metal to form a patch can't be that hard.
    Fix it right, weld the hole closed. Leave the brazing in the history books.
    indyjps, Happydaze, jimmy six and 5 others like this.
  9. gimpyshotrods
    gimpyshotrods
    Yup, 100% Argon. Make sure both sides of the metal are as clean as you can get them.
    Kroombit and Kingscustom like this.
  10. Kingscustom
    Kingscustom
    Yeah I'm thinking this would be my best option because I know my welder and setting required for sheet metal. I'll most likely get after it with 3/32 er70 and good chunk of 1" aluminum ****img heat out as I go
  11. gimpyshotrods
    gimpyshotrods
    What issues? Can you elaborate?
    I have been using silicon bronze on body panels for about 15-years, on about 50-cars. That is a combination of MIG brazing for tacks, and TIG brazing.
    There has not been one single issue with any one of those seams.
    My daily driver has about 15-feet of TIG brazed seams, and that includes the fuel tank!
  12. Kingscustom
    Kingscustom
    This is the reason I asked. I Tig stainless ***anium, aluminum, carbon steel.. zero auto body experience so thats why I asked. But I mentioned tigging them up with er70 and I will most definitely go that route after all the replys I have got i figured I would give silicon bronze rod a try never messed with it but sounds like I should leave it alone and fill the holes with er70
  13. I’ve done a good bit.
    OEs now use it on panel joints but using a MIG process. I’ve dug into several European cars with bronze seams.
    I normally make a new piece for rust but for random holes dropping some bronze in a hole is super easy.
    Those old screw holes for “yanking out dents” fill up easy.
    I can planish it out smooth and takes less heat. Never had an issue.
  14. gimpyshotrods
    gimpyshotrods
    Don't let people scare you off of trying new things. Grab some rod and try it on some s****.
    It is not at all hard, and won't be for you, as you already know torch, rod, and puddle control.
  15. gimpyshotrods
    gimpyshotrods
    Yup. My experience is exactly the same.
    saltracer219 and anthony myrick like this.
  16. Kingscustom
    Kingscustom
    I'll keep you updated on what I do. I'm just up north from you in Sacramento
  17. gimpyshotrods
    gimpyshotrods
    Sweet!
  18. junkman8888
    junkman8888
    Most of my auto-body experience was gained back in the 70's, back then most body men believed brazing was a sub-standard method of repair used by knuckle-draggers who didn't have the talent or inclination to do the job right because no matter what you did to remove the flux that br*** would always come back to haunt you.
    This leads me to the next question: Who are you doing this work for, you or someone else? I promise you no customer will want to see br*** anywhere on their vehicle if it wasn't put there by the factory.
    Wanderlust likes this.
  19. Wanderlust
    Wanderlust
    ^^^^^ find me in same category ^^^^. I’ll mig it up with copper backing before I’ll **** with brazeing
    juan motime likes this.
  20. Mr48chev
    The reasoning is lower chance of distortion. He's not some rube who lacks skills and only has a torch and a box of brazing rod.
    My own experience and I'd say most of the guys here with br*** in non structural non stress spots is that the acid all too often comes back to beat your **** no matter how much effort you put into cleaning it off.
  21. gimpyshotrods
    gimpyshotrods
    Hate to say this, but it is not 1955, 1965, or even 1995.
    Technology and practices change.
    And it is not Br***. It is Silicon Bronze.
    saltracer219, Blues4U, Tman and 2 others like this.
  22. gimpyshotrods
    gimpyshotrods
    Yup, and with MIG and TIG brazing, there is no acid.
    No acid, no "brazing problems", which is the origin of the "brazing is bad" mindset.
    HotRodWorks, guitarguy, Tman and 2 others like this.
  23. junkman8888
    junkman8888
    I very much realize it's not the 70's anymore, that the auto body repair/repaint industry has changed dramatically over the years with new products and procedures but none of that matters when it comes to changing the mindset of a customer, and the customer is the one paying the bills.
    Let's just imagine that a customer brings in a '32 Ford roadster to have a quarter panel replaced, you gonna weld it on or use bronze? Just because a new product or procedure is "acceptable" by the industry doesn't mean the customer is going to agree to it. (if you really want to see fireworks shoot out of someone's *** let the customer catch you gluing that quarter panel on using "panel-bond").
  24. You will when you have your new car repaired to OE specs. Silicon bronze that is, which is the subject of discussion. Not the same as br*** with a torch.
    Todays knuckle dragging body men mig weld everything (or panel bond) Funny how things change.
  25. 51504bat
    51504bat
    I really don't know didly about the fine points of panel replacement but If the guy/shop that's doing it knows their stuff I'm sure as hell not going to tell them how to do it. As long as its quality work that's done correctly so be it. Just my 2 cents.
  26. Kingscustom
    Kingscustom
    This is my car and I would be using silicone bronze filler rod not br*** rods
    saltracer219 and gimpyshotrods like this.
  27. Kingscustom
    Kingscustom
    Here is a pic I found in my phone of my TIG work. Mild steel. 095 wall with 1/16 er70s2 filler. The main reason I wanna use silicone BRONZE filler rod is, it wets in very smooth and nice as well as keeping lots of heat out of thin sheet metal. When I get home from work I will take some pictures of what my simple shop garage is
    gimpyshotrods likes this.
  28. Ever see the brazed structural joints on a jaguar?
    gimpyshotrods and Kroombit like this.
  29. Kingscustom
    Kingscustom
    No I have not, I have a feeling I'm going to Tig every hole, crack and filler panel with silicone bronze rods on the entire body. I would love to see them if you have a link or pics
  30. Budget36
    Budget36
    I know this discussion is in regards to filling holes, maybe I missed it but can patch panels be **** welded with the Silicon Bronze as well?
