TIG Welder Controls Help...
Discussion in 'The Hokey Ass Message Board' started by fiftyv8, Oct 25, 2013.
  1. 2racer
    2racer
    get the chinese learn to weld dvds....problem solved
  2. fiftyv8
    fiftyv8
    from CO & WA
    For those who have just joined this thread, I know the translation for each of the 4 dials, but I would now like to know what each dial does for me and how it influences the welding process???
  3. Happydaze
    Happydaze
    The toggle, bottom right, i'd say switches the pulse function on an off. Switch it off and then the peak current knob is all you'll need to get you going. I have a tig with pulse function and never use it.
    Strange that the machine has pulse but no obvious facilities for slope in / out and pre / post gas flow.
    If you've welded before (gas / mig / stick) you should get it pretty quick. Otherwise it might be worth getting cl***es or some instruction from a buddy?
    Lots of help on youtube too.
    Chris
  4. hotrodarchaeologist
    hotrodarchaeologist
    from Maine
    I think you have a great conversation piece, especially if you manage how to read / use it properly!
  5. fiftyv8
    fiftyv8
    from CO & WA
    Yes, I regularly use a MIG welder and can stick weld but dont much anymore.
    Gas welding I was never that good at it due to lack of practice mostly.
    Thanks for the info.
  6. fiftyv8
    fiftyv8
    from CO & WA
  7. Canus
    Canus
    The library and your local community college are both excellent resources.
  8. hugh m
    hugh m
    from ct.
    There is a Monster Garage book out there, Think it's called How to Weld Damn Near Anything...it's a reprint of an earlier book, but in color. It has pretty good step by step instructions, we keep ours on top of the tig machine, so the guys can refer to it. Not too technical, and great for beginners.
  9. fiftyv8
    fiftyv8
    from CO & WA
    Thanks Hugh, just ordered a copy thru Amazon.
    Should be very helpful...
