Tig welding question?
Discussion in 'The Hokey Ass Message Board' started by junkyardgenius, Apr 8, 2012.
  1. junkyardgenius
    junkyardgenius
    from Kernow
    My welding helmet goes down to a shade 9. Is there a lower shade for Tig welding at low amps? I struggle a bit when welding at around 20 amps or less.
  2. No_Respect
    No_Respect
    from So-Cal
    The flash is a lot brighter on a TIG than MIG so I don't think you would want to go less than 9 I have a miller helmet and never go less than 11
  3. kelzweld
    kelzweld
    Maybe a differenty helmet and an 8. They're availiable.
  4. ems customer service
    9 is bottom i never go less than 10 and sometimes high as 14, they do come in colors green, blue, yellow and red, sometimes a color change will help a lot,
    also make sure your lens is clean and scratch free, it may not look dirty but it can make a big diff. a gl*** clear lens in front of the #9 lens will be more clear than a plastic one, but i always leave plastic on the inside for safety.
  5. ems customer service
    another issue is background lite, try putting a towel over the back of your head to keep out backgound lite,
    20 amp tig weld is very small puddle, magnifing lens on the inside
  6. swe64
    swe64
    try reading gl***es it helped me 1.0
    ken
  7. Hot Rod Grampa
    Hot Rod Grampa
    I use an extra light to help see. Got a 500W halogen cheapie that helps a lot without compromising the eye protection.
  8. 2nd that.... get a light on your work
  9. metal man
    metal man
    Sounds like a good idea to me. I have #8 lenses in my drawer that I have never used. I worry that it would damage my eyes?
    I have known other really good welders that have used reading gl***es.
  10. metal man
    metal man
    The background light can also create havoc as stated above. Reflections of lights behind you can be brighter than the puddle.
  11. Willy301
    Willy301
    I wear reading gl***es, and step up the lighting on the work....X2 on the back light, but I think a towel on your head is a possible chance to get a bad burn if you happen to spark and it catches...So if you are gonna use a towel, dampen it slightly with water... It will burn you before you know it is on fire!
  12. syracusegli
    syracusegli
    from ny
    what kind of hood do you have? a good one or a harbor freight? x3 on back light. just curious what are you welding with only 20 amps(or less) ?
  13. NORSON
    NORSON
    I'm old and wear trifocals. To weld I use perscription reading gl***es and a magnifier in the helmet. You can't see anything with multi-vision lenses. A miller helmet set at 9. I'm going to try the towel an light. Thanks. Norm
