Tight Fit- What Oil Fliter SBF in 50 Ford ?
Discussion in 'The Hokey Ass Message Board' started by fordstandard, Dec 3, 2011.
  1. partsbob67
    partsbob67
    from california
    fl300 has the same gasket and threads as an fl1a. it's just shorter. fl400 is a different diameter.
  2. RopeSeals???
    RopeSeals???
    I found a really short (like 2 1/2") Wix Filter that was used on a Renault for a 302 powered Jeep...
    Part Number: 51335
    UPC Number: 765809513358
    Principal Application:
    Agria, Aksa, Bomag, Dynapac, Lister, Farymann, Renault, Saab-Scania, Other
    All Applications
    Style: Spin-On Lube Filter
    Service: Lube
    Type: Full Flow
    Media: Paper
    Height: 2.483
    Outer Diameter: 3.670
    Thread Size: 3/4-16
    By-P*** Valve Setting-PSI: 8-11
    Anti-Drain Back Valve: Yes
    Beta Ratio: 2/20=6/20
    Burst Pressure-PSI: 280
    Max Flow Rate: 7-9 GPM
    Nominal Micron Rating: 21
    Gasket Diameters
    Number O.D. I.D. Thk.
    15614 2.834 2.462 0.255
    Here's the 1 QT Ford Filter info:
    Part Number: 51515
    UPC Number: 765809515154
    Principal Application: Chrysler Family of Cars/Trucks (57-70), Ford Family of Cars/Trucks (57-00), Mazda Trucks (94-00), Toyota Landcruiser (71-96), various HD applications - (Two Quart version is 51773)
    All Applications
    Service: Lube
    Type: Full Flow
    Media: Paper
    Height: 5.178
    Outer Diameter: 3.660
    Thread Size: 3/4-16
    Ends: Metal
    Burst Pressure-PSI: 290
    Gasket Diameters
    Attached 2.834 2.462 0.200
  3. Here in Oz i have used a Ryco Z89A. This is the filter used on 2.0 litre OHC Ford 4 cylinders in the 70's.
  4. fordstandard
    fordstandard
