Technical Tilt front end
Discussion in 'Traditional Hot Rods' started by West40, Jan 3, 2021.
  1. West40
    West40
    Looking to do an all steel tilt front end on my 40 plymouth. I'm new here.
  2. Bob Lowry
    Bob Lowry
    I did these many, many years ago....'41 Plymouth and a '40 Chevy. Just bolted all of the panels
    together and made simple hinges with thin cable for opening stops.
    j hansen, j-jock, VANDENPLAS and 9 others like this.
  3. roddering
    roddering
    from Arizona
    I found these HD hinges on Amazon.
    VANDENPLAS and AHotRod like this.
  4. 1971BB427
    1971BB427
    from Oregon
    I've done a number of them, and done them bolted and welded together. Need to be sure to space the factory gaps between fenders and hood, as if you don't the whole front clip will be narrower than the body it ****s to. I've also found that if you want it to be a one person operation to open it, you need to split the fender drops so the fenders don't drag across the doors, or body.
    The pivot point for the frontend will affect how easily it opens also, and keeping it lower will make it easier to open. Be sure the hinge points are heavy, as that's a lot of weight to pivot on two points. Also be sure to reinforce the front clip with a tubular framework so it doesn't flex constantly as you drive, or as you open it. And add extra reinforcement around the connection point to the front clip! It's easy for the pivot point to stress the sheet metal and crack out if not plated, and reinforced.
    This is the framework I built from 3/4" EMT tubing for my Falcon.
    A much sturdier restraint cable is great! I use tailgate cables from pickup trucks I get at the wrecking yard for a few bucks.
  5. seb fontana
    seb fontana
    from ct
    Been working since 1976, 44 years.
    roddering, j-jock, blowby and 4 others like this.
  6. ekimneirbo
    ekimneirbo
    The one thing I would do is to see if the ***embled front can tilt without haveing to cut the fenders so they don't rub the body when opening. If they are going to rub, I would incorporate some type of slide similar to the slides on toolbox drawers but stronger...............that would let the front move forward before opening, then back once its open.
    brigrat and Bob Lowry like this.
  7. 1971BB427
    1971BB427
    from Oregon
    If you look at the picture I posted, you'll notice the toggle link system I designed to let the front clip move forward 6" before I tilt it open. Simply pull on the front clip and the link flops over. Then tilts forward. Works without needing a 2nd person to ***ist.
    And this is my Austin in my avatar. Both cars have the fender drops cut off and attached to the body to make it easy to open. But that also ensures they wont hit your head when you're working on the engine too! Imagine those fender drops attached to the fenders, and where they'll sit when the clip is open? Right in the way when you're back and forth working on the engine!
    j-jock, AHotRod, mgtstumpy and 2 others like this.
  8. lowrd
    lowrd
    I saw a 39 Buick with a tilt nose which was pulled forward away from the firewall before tilting, avoiding cutting the fenders. The hinges were mounted on tubing, sliding inside another tube mounted to the frame.
    ekimneirbo and fiftyv8 like this.
  9. brigrat
    brigrat
    from Wa.St.
    Back in the, '70's? GM cars came with collapsible steering shafts, they are held solid with imbedded hard plastic. Once you break that plastic the inner and outer shafts will telescope longer or shorter. Cut the ends off, cut to length and you have a way of pulling tilt front end away from firewall and fenders, works great!
  10. blue 49
    blue 49
    from Iowa
    The best thing you can use for hinges are spherical rod ends (Heim joints). Mine are bolted to a plate with slotted holes so they can be adjusted fore and aft and the threaded shank can be adjusted for up and down. The pivot point is a ball so there is never any bind. I used 1/2" ones, and they are plenty strong.
    Gary
    Paulz and AHotRod like this.
  11. wvenfield
    wvenfield
    You could way over engineer it. It works with one person and we didn't have to cut the fenders though.
  12. brigrat
    brigrat
    from Wa.St.
    Do you sell that in a kit form?
    kidcampbell71 likes this.
  13. wvenfield
    wvenfield
    If you knew how long it took us you couldn't afford it in kit form. LOL
    I imagine it would have to be done differently for each car also.
    fauj, kidcampbell71 and seb fontana like this.
  14. seb fontana
    seb fontana
    from ct
    Looks like the fender tops hit the doors..
  15. brigrat
    brigrat
    from Wa.St.
    I was being facetious? smileyface!
    wvenfield likes this.
  16. mgtstumpy
    mgtstumpy
    I did this on my 48 GM Holden in the 70s, it's still around today. Bolted everything together as others have done and hinged front end on both bar brackets with fenders split on line. Lock pins on each side allowed front to be tilted by one person when disengaged. A stout bushing on the pivot point is necessary. In hindsight I could have slid it forward like the 55 however I wanted to drive it as soon as possible. There was a similar 48 Holden built around this time, the front slid and tilted and was held down by Triump Herald latches rather than my pins.
    Sporty45, AHotRod and reagen like this.
  17. 5window
    5window
    Nice job. Back when I was a lad, and before I wisely chose hot-rodding, I had a Triumph Spitfire where the whole front end tilted. It secured with those Tirumph latches on the sides like you've pictured. Very easy to work on everything. It was very light, my cl***mates just carried it off from the parking lot one day. Although seriously OT, I'd like to have it, and my 1968 waistline, back again.
    Budget36, osut362 and mgtstumpy like this.
  18. wvenfield
    wvenfield
    If you are looking at the paint chips, they have been there forever.
  19. ekimneirbo
    ekimneirbo
    Thats a very nice set up. You could help others by posting some dimensions and pictures of the mechanism in a few stages of the movement. Appears to be two separate considerations. One for tilting one for pivoting forward. Thanks for sharing it.........;)
    Tickety Boo and LOST ANGEL like this.
  20. chopped
    chopped
    Wonder what happened, guy hasn't been back since first post.
  21. wvenfield
    wvenfield
    I don't have dimensions but there is a long build thread. I don't even remember what all is in it. LOL
    https://www.jalopyjournal.com/forum/threads/1956-pontiac-g***er-389-swap.949269/#post-10683336
  22. Hoods on 1980s BMWs had hinges that were sprung so that the spring on the hinge lifted the front of the hood and moved it forward enough that the rear of the hood released from a pair of hooks at the rear.
    It works really well, and something like that could be copied for a tilt front end.
    I saw a home built hinge on a 56 Ford, which did not move the front end forward, and it didn't allow the new ***embly to move forward enough, or open enough, to provide proper access to the engine.
    Bob
    Ned Ludd likes this.
  23. atch
    atch
    late 80's Buicks (LeSabre & Park Avenue) did the same.
    Bob Lowry likes this.
  24. Budget36
    Budget36
    I recall someone posting (somewhere) pics they did, looked like larger drawer slides, pulled forward then flipped up. I thought it was neat, but don't recall the details.
  25. WZ JUNK
    WZ JUNK
    from Neosho, MO
    Thats how the fibergl*** tilt front works on my truck that is my avatar. I built it that way about 30 years ago. Although it works good, I plan to change it some this winter. I have started work on the truck recently to update and fix some things that have been neglected to long.
  26. Bob Lowry
    Bob Lowry
    brigrat and roddering like this.
  27. blowby
    blowby
    from Nicasio Ca
    Mine slides forward, just 1" square tubing sliding inside 1-1/4" tubing. Simple but effective. And it will slide all the way out for easy removal. Also my hood is separate, hinged at the back. Nice because I can do carb work etc. without tilting the rest.
    Old photo, all I got at the moment.
  28. 41rodderz
    41rodderz
    from Oregon
    Great thread and links . I want to do a flip on my ‘48 F1 , so I can get to things easier. Not wanting to work head first with feet sticking in the air like a pair of exhaust stacks .:p
  29. 1971BB427
    1971BB427
    from Oregon
    This is the same setup I built for my '63 Falcon g***er, except my toggle links aren't as long, so it only moved forward about 6"-7". It made flipping the links over easier, and I didn't need more clearance.
  30. atch
    atch
    I wanted to search for an old thread that I started so I could reference it here. I searched for "tilt" in "***les only" and several threads came up. Some were for tilt front ends, some were for tilt columns, and some others. You can sift through and read many threads regarding tilt front sheet metal.
    Here are the search results for you to peruse.
