Hot Rods Time for...Guess that suspension!
Discussion in 'The Hokey Ass Message Board' started by GomezGarage, May 20, 2014.
  1. GomezGarage
    GomezGarage
    Hello everyone, customer just dropped this off and we are all betting on whats it is. The HAMB has settled a lot of "discussions" in the shop before, so away we go...HA Ray frame 1.jpg Ray Frame 2.jpg Ray Frame 3.jpg ...HA
  2. chaddilac
    chaddilac
    Wow... that's weird lookin'!
  3. HOTRODPRIMER
    HOTRODPRIMER
    Dangerous!,a wreck looking for a place to happen!
    Cut it out and start over,. HRP
  4. junkyardjeff
    junkyardjeff
    Probably European design
  5. GomezGarage
    GomezGarage
    Well, that's the shops opinion already...HA Plus he wants a blown big block! Just looking at those 1/2 inch OD uppers is scary enough
  6. Grahamsc
    Grahamsc
    from Colorado
    I bet someones missing a cheap swingset and a couple of pogo sticks.
    Muttley likes this.
  7. Cliff Ramsdell
    Cliff Ramsdell
    Thats ah...OK, I know....is just spindly looking and very scary.
    Cliff Ramsdell
  8. Cliff Ramsdell
    Cliff Ramsdell
    Holy ****, blown big block. Might as well put a coffin on there for a body, just to save a step later.
    Cliff Ramsdell
  9. OFT
    OFT
    R&P looks like something from a Fiat. Rest may be also.
  10. tb33anda3rd
    tb33anda3rd
    it is probably not but at first glance i thought of atv front end
  11. Me too! Thought it liked pretty atv like
  12. lostone
    lostone
    from kansas
    It looks like some kind of stock spindle turned upside down and swapped side to side and the rest look like home made parts.
    I would say its time to start all over and just get rid of all of it.
  13. gnichols
    gnichols
    from Tampa, FL
    Something from an ultra-lite drag car? Gary
  14. GomezGarage
    GomezGarage
    As previously stated, this set up is junk and will never handle the blown big block this customer has to have! We just bench race about **** and are trying to find the origin of this kooky at best front suspension.
  15. need louvers ?
    need louvers ?
    I seem to remember something like this from a company called Maas, or something similar. Opel components if I remember correctly. They had one version that used the stock Opel stamped arms and lower cross spring, then this one that was their custom tubular unit.
  16. s55mercury66
    s55mercury66
    from SW Wyoming
    I'll be the odd man out here, and say I kinda like it. Chrome moly? What is it installed on now, a T-Bucket?
  17. wingedexpress
    wingedexpress
    I don't know what the parts came from . I say it was meant for a light VW type buggy as it looks to have some long suspension travel.
  18. mcbrideluo
    mcbrideluo
    HA Plus he wants a blown big block![​IMG]
  19. gimpyshotrods
    gimpyshotrods
    That belongs in the s**** bin, after you cut it up, so no other fool uses it.
  20. alchemy
    alchemy
    The geometrics of the thing may be fine, but the heft isn't there. I'm always interested in seeing different designs and articulating them in my brain. This one may just work OK. Would probably be fine in a very light car (Anglia?) with a small 4 above it.
  21. Remove the tie rod ends, thread a rope through the holes and get your buddies to push you around in the car park after some brews.
  22. Probably a Lotus prototype and worth more than you and your ten best friends! That being said, I wouldn't put a blown big block above it.
  23. 26 roadster
    26 roadster
    Reminds me of Mustang II design, I also have issue with strength but it unknown what it is made of.
    I have seen drag cars with 3/8" heims on the four bar front and Hose clamps holding engines in fuel cars so...............
  24. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Much like playing "what did I have for lunch?"
    I could poop in a box and you could guess tacos..... but either way, in the box, and on that frame is just poop.
    Might work fine or a 4banger, or ATV motor. Blown big block, I'll p***.
  25. models916
    models916
    I've seen circle track stuff run that single arm lower.
  26. Ebbsspeed
    Ebbsspeed
    It does look like a variation of a Mustang II with that single lower arm and lower arm strut. Probably work OK if it was built of heavier components.
  27. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
  28. 70s dune buggy . vw powered. not good.
  29. GTS225
    GTS225
    Whoa! Wait a second guys. That isn't necessarily s****. I could use some of those components on a small cargo trailer I have in mind for pulling behind my T. (about the size of a large trailer for behind a motorcycle.) But then, I don't plan on hauling around a running fat block in it, either.
    Roger
  30. Ryan
    Ryan
    ADMINISTRATOR
    Not traditional.
