Does anyone know someone in the Pompano Beach Florida area that can PROPERLY time a flathead V8 with a ready to run dist. electronic ignition? Thanks in advance joe smith
Once you get it running,use a vacuum gauge .manifold vacuum .Adjust the dist to get the best possible vacuum at idle,then back off a hair.should be good.if car pings ,back off on dist till pinging goes away.
