Technical Timing a Ford 390 FE
Discussion in 'The Hokey Ass Message Board' started by Ausy, Jan 27, 2016.
  1. Ausy
    Ausy
    Hi Guys.
    Quick question
    Trying to time a Ford 390 FE in a 63 Ford Galaxie 500. Engine has not been started in 40 years. No 1 is on TDC. No matter how many teeth i skip between distributer and cam, its keeps ending up too advanced or too retard. (Rotor ****on between cap posts, or even a full post out). Harmonic balancer has not moved. 100% sure that I'm on TDC. Any idea on the solution?
    Cheers
  2. Bigblue61
    Bigblue61
    While the guys here are on top of their game, if you need FE info, you may want to save this web address. These guys live, breathe and bleed Ford FE:
    http://www.network54.com/Forum/74182
  3. 57Custom300
    57Custom300
    from Arizona
    Is the oil pump shaft not allowing it to drop down where you want it? Sometimes the oil pump shaft won't allow the distributor to drop down if it's not lined up with the hex drive on the bottom of the distributor shaft. Try installing it with the rotor pointed to #1. If the distributor won't drop down all the way, turn the engine over until it drops down then bump the engine around until your timing marks line up and check the rotor position. No need to go to some other site for this it's really not that difficult.
  4. Ausy
    Ausy
    You are correct. It's not going down where I need it to go. By rotating the engine, this won't turn the hex drive on the pump will it? The oil pump is driven by the distributer?
    I also noticed that the hex drive moves about in the slot?
    Many thanks for the quick reply.
    Cheers.
    Tim
  5. V8 Bob
    V8 Bob
    Have you checked the point dwell? The engine may run with the dwell way off, which directly affects timing. Also, make sure the mechanical advance moves free and not stuck, along with disconnecting the vacuum line.
  6. Rex_A_Lott
    Rex_A_Lott
    Yes , the distributor drives the oil pump. On a SBC its a simple matter to turn the oil pump w/ a long screwdriver, but you dont have that option. You could do it if you had an old distributor shaft without the gear. Maybe able to get to it with a long 1/4 drive extension and the right socket. I think its 5/16, but I may be wrong. Just look at the bottom of your distributor shaft.
    Good Luck
  7. Judd
    Judd
    But it will turn the distributor till it lines up with and drops down on the oil pump drive shaft.
  8. Ausy
    Ausy
    Thanks guys, all sorted.
    Cheers
    Rex_A_Lott likes this.
  9. Jalopy Joker
    Jalopy Joker
