Timing issue? 53 Plymouth
Discussion in 'The Hokey Ass Message Board' started by NHMike, Jul 14, 2013.
  1. NHMike
    NHMike
    Okay gents. Finally got the Cambridge running well enough for the road. However, when I get up to about 55 she starts to stutter and it seemed to get progressively worse if I try to throttle through it. I can no longer turn the distributor clock wise as its gone as far as it can. By the timing light, it's close, but could still use another 1/4 turn of the distributor if it only had the ability.
    Any ideas?
    She's a 53 Plymouth with straight 6 and running 6V.
    Thanks!
  2. Rusty O'Toole
    Rusty O'Toole
    Move all the plug wires over one space and try timing it again.
    Do you know there is a small pipe plug in the head, above the #6 piston? If you take it out you can drop a screwdriver down the hole and feel the piston go up and down. This allows you to find out if your timing marks are accurate.
  3. NHMike
    NHMike
    Will do. I was curious about just moving the wires. I'll check for accurate tdc first. Thanks!
