Timken numbers for the Banjo???
Discussion in 'The Hokey Ass Message Board' started by dorksrock, Dec 7, 2007.
  1. dorksrock
    dorksrock
    I did a search and found the numbers i needed for everything EXCEPT the pinion pilot and the wheel bearings... does anyone have a standered number for these bearings? :confused: I have the ford part numbers for the wheel bearings 68-1225, and for the pilot bearing 18-4625-a... if that helps you at all... :D
    Thanks!
    Jordan
  2. dorksrock
    dorksrock
    Nobody has these? I would think that some one on here would!
    Thanks...
    Jordan
  3. **** Spardo is a HAMB member. He sells early Ford parts and has a lot of knowledge. Send him an email or PM.
  4. FritzJr
    FritzJr
    <TT>Ford Rear Bearing Interchange</TT>
    </PRE>
    <TT>Ford # Bower/Timken<O:p</O:p</TT>
    </PRE>
    <TT><O:p</O:p</TT>
    </PRE>
    <TT>18-4221 22168<O:p</O:p</TT>
    </PRE>
    <TT>18-4222 22325<O:p</O:p</TT>
    </PRE>
    <TT>68-4221 25576<O:p</O:p</TT>
    </PRE>
    <TT>68-4222 25522<O:p</O:p</TT>
    </PRE>
    <TT>B-4245 -------<O:p</O:p</TT>
    </PRE>
    <TT>48-4621 27880<O:p</O:p</TT>
    </PRE>
    <TT>48-4616 27820-D<O:p</O:p</TT>
    </PRE>
    <TT>18-4625-A ------<O:p</O:p</TT>
    </PRE>
    <TT>78-4658 -----</TT>
    </PRE>
    <TT>59T-4625 (Narrow Type) crosses to a Bower # MRY-1305 or M1305E or U1305</TT>
    </PRE>
    <TT>81T-4625M (Wide Type) crosses to a Bower # U-1305TA</TT>
    </PRE>
  5. Bruce Lancaster
    Bruce Lancaster
    From this useful site, some Model A numbers, some of them useful up through 1948:
    http://www.jmodela.2ya.com/
    BEARING CROSS REFERENCE NUMBERS
    Thanks to Steve Becker of Bert's Model A Ford Center in Denver, Colorado, 1-800-321--1931, and to D.J. Voyce of Africa for the source of these numbers. If you have any other bearing cross reference numbers (rear wheel, transmission, etc.) please p*** them along so I can add to this list.
    FRONT WHEEL BEARINGS FORD NUMBER 799000 SERIES BEARING NUMBER APPLICATION YEAR
    B1201 799072 15118 INNER CONE 1928-1942
    B1202 799076 15250X INNER CUP 1928-1942
    B1216 799061 09074 OUTER CONE 1928-1942
    B1217 799065 09196 OUTER CUP 1928-1942
    B1225 SKF 00536 Bower 66-2456
    or J662456 REAR WHEEL BEARING 1928-1936
    PINION BEARINGS FORD NUMBER 799000 SERIES BEARING NUMBER APPLICATION YEAR
    B4221 799085 28156 CONE
    (2 USED) 1928-1932
    B4616 799086 28314D
    28314XD PINION DOUBLE CUP 1928-1932
    DIFFERENTIAL BEARINGS FORD NUMBER 799000 SERIES BEARING NUMBER APPLICATION YEAR
    B4221 799085 28156 CONE 1928-1932
    B4222 799087 28317 CUP 1928-1932
    MISC. BEARINGS FORD NUMBER Modern number APPLICATION
    A10093 6203 2RS GENERATOR SHAFT BEARING(FRONT)
    B3123 799003
    T83 (Timken) SPINDLE BOLT
    BEARING ASEMBLY
    7 TOOTH STEERING WORM THRUST BEARING
    A7025 6208 2RS MAIN DRIVE GEAR BEARING
    BALL BEARING
    A7118 J-241248 (BCA) COUNTER SHAFT BEARING
    SHORT;
    ROLLER BEARING
    A7065 6306 2RS TRANSMISSION MAIN SHAFT BEARING
    A7580 AR NICE BALL BEARING CO. of Chicago Number N-576. CLUTCH THRUST BEARING
    MULTI DISC CLUTCH
    A7580 RB9707 (SKF) CLUTCH THRUST BEARING
    A7600 6203 2RS (Single disc clutch) CLUTCH PILOT BEARING
    MISSING BEARING NUMBERS FORD NUMBER BEARING NUMBER APPLICATION
    A4645 DRIVE SHAFT BEARING
    A7121 BCA J24-1256 COUNTER SHAFT BEARING
    LONG
    A7600 AR CLUTCH PILOT BEARING(MULTI DISC CLUTCH)
    A8530 WATER PUMP SHAFT ROLLER BEARING
    A10093 NTN6204
    LLBC3/5C
    SKF6204-2RSJEM GENERATOR SHAFT BEARING
    POWERHOUSE
    LARGE
    STARTER REAR BEARING
    A10094 SKF6203-2RSJEM
    NTN 6203
    LLBC3/5C GENERATOR SHAFT BEARING
    POWERHOUSE
    SMALL
    A5230-1 MUFFLER BEARING
    Page designed by Jim Mason June, 2007
    HomeHow to:Original Parts1929 Ford FAXReferenceFine PointLinksInstall Belt MoldingInstall Sunvisor materialInstall Window gl***Pull an EngineQuestionsFit Main Bearing****k Rebuildable ShocksRebuildRemove the gas gaugeRemove broken studMake repop fender fitStart a Model AStraighten WheelsAre Modifications needed?Find Engine and Body Numbers (VIN?)Where do I Start?Mid 28 TransmissionMulti Disc ClutchAccessoriesBacking PlatesCanadianCarburetorsCompared to REPOPEarly 1928FansHeadlight SwitchesLittle partsMesstorationsNuts and BoltsPop-out SwitchesSpeedometersStarters & DrivesTiming CoversTool KitBasicCoolingFabricationLubricationMajorPowerhouse GeneratorTransmission1928 ***embly Bearing Cross ReferenceBody Style and Group Part #Book RecommendationsBill of Sale StudyBrake Grinder ManualGenerator charge rateColors 1928/1929 TudorsGl*** DimensionsHomemade ToolsModel A HistoryPaint CodesRivetsTwenty Millionth FordWiring DiagramTech article indexGary Karr's TudorHow judging worksInstruction Manuals
  6. Bruce Lancaster
    Bruce Lancaster
    Aaaaahhhh...Follow the URL. It seems somewhat scrambled as it posted. By the way, FORD numbers shown have A and B prefixes: Numbers that Ford left marked "A" in 1932 are things that fit A's only, those that were updated to "B" prefix fit at least 1932, and many of those work up through 1948.
  7. capseasick
    capseasick
    Did you ever find the bearing # for the Pinion bearing?
  8. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    Timken Part number: 25578
    You should double check just to be sure...
