Projects Timm builds a model A
Discussion in 'The Hokey Ass Message Board' started by Tim, Mar 8, 2016.
  1. 05snopro440
    05snopro440
    Also, are the top surface of your spring mounts on the frame now parallel with the top of the frame?
    porkshop likes this.
  2. Tim
    Tim
    from KCMO
    I’ll take a photo of the lazer tonight when I get home from work. It came with the tripod etc. it self levels up to a certain amount but it’s got a little bubble level right on the side of it so you don’t have to guess how close you are etc.
    @05snopro440 yeah the top is pretty close if not exactly parallel with the top flange of the frame rail. The boxing plates are inset 1/8” and the bottom of the spring mount bracket is pretty close to the bottom of the boxing plate. I did it that way so if I wanted to rotate the end of the bracket down to pre load the spring I didn’t need to move the bolt that holds the frame end of the spring. I can just pivot it.
    on that note, there are two triangle shaped gussets that will go on top of the spring bracket once it’s 100%
    drdave, Thor1, 05snopro440 and 4 others like this.
  3. Tim
    Tim
    from KCMO
    05snopro440, Six Ball and porkshop like this.
  4. patman
    patman
  5. Six Ball
    Six Ball
    from Nevada
    Thanks Tim, I'll check that out.
    Patman,Wow! Thank you! I'll be spending time going through that.
  6. Tim
    Tim
    from KCMO
    IMG_2743.jpeg Ran across town to a friends shop to get this old worn out 650’s off and get the 750’s on! IMG_2744.jpeg man that’s for sure the better way to do it! Grabbing lunch and I’ll have them bolted on soon!
    Deutscher, porkshop and drdave like this.
  7. Tim
    Tim
    from KCMO
    Man the diameter of a 750-16 is dead on the same as the wheel opening on a 28-9 sedan fender! IMG_2751.jpeg IMG_2750.jpeg un real. No wonder it looks so good! IMG_2752.jpeg got both mounted to the axle but the ride height is wrong.
    next step is lifting the frame and shifting the jack stands to get the *** end up at least another inch. When it was sitting atop the old banjo and wheels the top center of the wheel opening was right at 32” from the ground.
    that in theory gives me around 1/2” between the top of the tire and the fender edge at top center
    drdave, Thor1, winduptoy and 4 others like this.
  8. 05snopro440
    05snopro440
    Should be easy to adjust now with the spring height adjustment bolts?
    porkshop, Six Ball and winduptoy like this.
  9. Tim
    Tim
    from KCMO
    @05snopro440
    I think you missed the part where I took the rear suspension apart. But once it’s back together it should more or less be where it’s supposed to be. The frame is sitting on jack stands right now, I’m needing to get it sitting at ride height and the wheels centered before I put it all back together.
    But after all that if it needs to come up yes I can just use the adjustment bolts and get it dialed in :)
    winduptoy, porkshop, -Brent- and 2 others like this.
  10. 05snopro440
    05snopro440
    You're right, I didn't realize it was apart again.
  11. Tim
    Tim
    from KCMO
    Bout make a guy cross eyed doesn’t it. Lol
  12. Six Ball
    Six Ball
    from Nevada
    I have one of those Harbor Freight tire changers. It has paid for its self many times over, I have the motorcycle adapter for it too.
    porkshop and Tim like this.
  13. 05snopro440
    05snopro440
    I tried to bring mine into the garage tonight so I can work on it this winter. I failed. I'll try again in the coming days.
    I think I am going to fab a quick tow apparatus to hook to my tractor to make it easier to move.
    Just Gary, porkshop and Tim like this.
  14. Tim
    Tim
    from KCMO
    @Six Ball we were talking about how crazy it is that people try to use them with out it being bolted to something unmovable. Very handy tool, worked great.
    @05snopro440 good idea! Could put a strap around the perch pin. Grabbing the axle and wishbone or bolt a push bumper to the rear and shove it around.
    I’ve also seen a lot of anchored rings that you could throw a pulley on. Hook the car, run it threw and attach it to the tractor to pull it
  15. Tim
    Tim
    from KCMO
    Been a very up and down couple of weeks with this thing. IMG_2791.jpeg IMG_2792.jpeg IMG_2793.jpeg this morning I spent half an hour getting the frame blocked up to correct ride hight and centering the axle, dialing in the rear axle center line etc.
    The I spent 70 long minutes fighting the ladder bars. I really wanted to have it mocked up and tacked in today. But this car had other plans.
    I couldn’t get the front of the ladder bars into the cross member tabs with the ladder bars bolted to the rear. It’s just to tight and ya really gotta wiggle them around to get the bushings and etc in place.
    But with the fronts bolted to the cross member tabs- which isn’t attached to anything- I can’t get more than one bolt in to the rear axle tabs. With one bolt in the drivers side the p***enger side may as well be outside of the garage playing with the neighbors dog. It is not even remotely in the right place. It’s so far off it can’t even see the right place from where it is.
    these are things I unbolted moments ago. Did not remove from the car. And now. Not a chance it bolts back together.
    right now I’m thinking I remove the entire rear axle, ladder bars and cross member from the car. Some how get it together not in the car and then roll it into the car.
    but the problem I’m seeing there is the cross member is fit so nice and snug between the rails that I don’t know that I can maneuver the cross member into proper position with it all together.
    you can see the problem here.
    it’s as if I’m going to have to just randomly pick a placement for the cross member, then tack it in place. ***emble everything and see how wrong it is. Take measurements from there and try it again.
    I’m completely over it. It fought me at levels that even working on it out of spite could not conquer. I buried the car under moving blankets and cardboard boxes. Shut the light off and locked the door behind me.
    This is supposed to be something good in my
    Life and right now, it’s just a decade long running wheel. And I’m pretty ****ing done with it at the moment.
    I keep feeling like I’ve got it sorted only to then completely take it back apart and do it again, and then be excited I got it…. and then jokes on me it’s wrong and have to do it over again, and again, and again.
    guess you’ll get updates again after I have some epiphany of solution, or I light it on fire in the driveway and broom up the left overs into the bin.
  16. drdave
    drdave
    I hate it when things get to that level of frustration.....it should be working but isn't, and just keeps fighting. Time for it to sit and "think about what it's done." A little time off, a clearer mind and a fresh set of eyes later and I bet something just pops the light on and you aren't as far off from getting it together as you thought.
  17. Tim
    Tim
    from KCMO
    Yeah. I need a brake.
    I’ve been in a fair amount of pain the last couple of weeks and today has been pretty bad. I was hoping to distract myself with the car today and it just fought me, I need to find a book or something to read until I can physically manage this.
  18. drdave
    drdave
    .....model cars....just sayin' LOL
    osage orange, porkshop, Thor1 and 2 others like this.
  19. mixerman
    mixerman
    Sorry to hear about being in pain, I know the feeling. I delt with a sciatic nerve in my right leg back in September and couldn't do anything in the shop...It's hell getting old.
    Hope you start feeling better soon.
  20. 05snopro440
    05snopro440
    Sorry to hear you're burnt out on it right now (and in pain). I've certainly experienced the burnout on a project. @drdave nailed it, I sometimes let a project take some time to "think about what it has done".
    I'm a little confused about what isn't aligning. Seeing as the crossmember tabs are welded on as you receive it, is it the alignment of the crossmember to the axle or ch***is (since your ch***is has such a significant rake)? Or is it the axle brackets that are misaligned or not quite in the right spot?
    Hope you rest up and can find your motivation again.
  21. redzula
    redzula
    Man. I finally get caught up in your thread... just in time for you to have one of those days. I was there a couple months ago on my coupe. Walked away and came back after a couple days. Changed literally nothing just tried it all over again and it worked that time. Sometimes you both just need a break.
    Pros:
    -Stance is still killer
    -Tires fill the fenders great
    -Unchopped with that rake is what dreams are made of.
    -you know it works because it was just together a few days ago and you really didn't change that much to cause it to not work (that almost certainly means the solution will be something equally stupid)
    Cons:
    -it's just being a little beotch at the moment.
    -you're tired
    Get some rest. Give it some rest. You'll figure it out another day.
    Whats up with the pain? Did something happen or is this someone you've been dealing with?
  22. atch
    atch
    Well, @Tim, you remember what the gov't hacks told Lone Watie (Chief Dan George), who then related same to Josey Wales (Clint Eastwood): "You must endeavor to persevere."
    There ya go...
    osage orange, porkshop, Tim and 2 others like this.
  23. Bandit Billy
    Bandit Billy
    I hope it is not an emergency brake!
    Seriously, we all need a break from time to time. Cars are supposed to be fun and the****utic, but they can turn into quite the opposite. We can be our own worse bosses, setting unrealistic expectations, being overly demanding, micromanaging and ruining moral in the workplace. I go on strike once in a while, declare a holiday, go golfing or just pour a nice Vicodin and bourbon and take a mental vacation. Bosses, they're the worst!
  24. Six Ball
    Six Ball
    from Nevada
    Maybe you need to borrow Lone Watie's piece of candy that "is of lookin' through" to see the problem. Just let it be and I bet you'll wake up in the middle of the night with the answer.
  25. Tim
    Tim
    from KCMO
    Hey guys, thanks for all the comments. I do appreciate the community here.
    I work on the car a lot as something to keep my mind occupied, and to cope with stress as I’m sure a lot of us do.
    I also never let hurting keep from getting stuff done… typically.
    It just wasn’t my day today. The ladder bar dance, I think I know how I’m going to attack it when I go back but it basically felt somewhere between trying to put shoes on a 110 lb dog and playing catch by yourself.
    I’ve been in an unusual amount of pain for the last couple months but I was dealing with it, but this morning I kicked a door frame getting ready for the day and broke my pinkie toe. By the time I got to the garage to work it began to hurt to breath. I’m not sure what I did but it feels like I bruised a couple ribs. I couldn’t lift my lunch with my right arm with out my torso hurting. Over the afternoon the pain got a little better but my hands keep going numb/tingly. I think I probably have a m***ive knot or a pulled something or other.
    either way I knew when I walked in there that I probably shouldn’t even bother but you know how it goes.
    I’m gonna give it a week or two and then hopefully with out a lot of ouch I’ll get back to the car.
    I’m not/wasn’t feeling burnt out as much as angry/defeated/frustrated. I’ll figure it out.
  26. When you figure it out -- and we know you will (you're one of us) -- it will be something small, obvious and/or overlooked. And I hear you on the pain front, too. We grind through in pain, knowing that discomfort has to be endured to get **** done.
    Thor1, redzula, porkshop and 3 others like this.
  27. Tim
    Tim
    from KCMO
    I’ve got an idea for “step one” but I’m going to leave it covered in the garage until Monday. It’s not easy but forcing myself not to do anything to physical is making me feel quite a bit better so far.
  28. drdave
    drdave
    smart idea
    porkshop, Tim and osage orange like this.
  29. Six Ball
    Six Ball
    from Nevada
    The Model A will be there when you feel like working on it.
    porkshop, osage orange and Tim like this.
  30. Tim_with_a_T
    Tim_with_a_T
    I missed out on the frustration- I’m sorry you’re having a rough time with it. If it’s any consolation, when I set up the ladder bars on the T, it was a real b-word to get it lined up- I had to use a combo of a jack, jack stands, and ratchet straps to hold/maneuver into place. I too became very frustrated and I’m pretty sure it took months to sort out. It’s not fun to work on something with little wiggle room, but holy smokes was it worth it - that car dead hooks and goes straight! So hang in there - you’ll get through it and it will be worth it from the other side.
    Short ****ogy from the youth of young Tim_with_a_T:
    My dad used to get frustrated with me because I never really applied myself in sports (because I didn’t care) and didn’t have to really try in school (college was a completely different story). But anyway, my dad would lecture me and say, “if you would try half as hard at things as you do with skateboarding, you would be wildly successful”. It took awhile for me to understand how to apply that lecture into my life, but he was right. I was willing to get completely broke off for skateboarding, eating pavement was just another day at the office. And when I’d be trying something I *knew* I could do and it just wasn’t there - and all the usual throw my skateboard, punch my skateboard, have a full public meltdown yelling into the abyss, I’d exhaust myself to the point where I had no choice but to go sit on a curb for a bit - calm down, think about what was happening, and go try again. Relentless and unwilling to give up. Anyway, I’ve appreciated that lesson, because life, and certainly hot rods, are no different. It’s not easy and failure is served for breakfast, lunch and dinner more often than not, but you’ve tasted success before as well and you know what that’s like. I think we’re always chasing that high. For skateboarding it’s rolling away from the battle, for cars it’s getting a rolling ch***is, first fire up, first drive etc. Anyway, all that to say, you’re beat up and momentarily defeated, but we know you better and we know you got this.
    Last little note- get your chest checked out - might not be broken ribs but something going on in your lungs or something and you don’t wanna snooze on that.
