Projects Timm builds a model A
Discussion in 'The Hokey Ass Message Board' started by Tim, Mar 8, 2016.
  1. Tim
    Tim
    from KCMO
    Yeah I’m going to try and find a photo of how they where originally used
    Stogy likes this.
  2. Inked Monkey
    Inked Monkey
    Glad she liked it.
    @Austin kays Yours is ready and waiting
  3. Six Ball
    Six Ball
    from Nevada
    People were way more into their clothes then. One thing I like seeing in old photos is how folks are dressed. Especially in the old car show pictures. We are such slobs now. "Clothes make the man. Naked people have little or no influence on society."Mark Twain
    Thor1, Stogy and loudbang like this.
  4. drdave
    drdave
    Looks like you got a lot done this week while I was off the grid! Figuring out where the important stuff has to and can go is quite the job sometimes.
    Thor1, loudbang and Tim like this.
  5. Tim
    Tim
    from KCMO
    @drdave just chipping away at it
    drdave and loudbang like this.
  6. RICH B
    RICH B
    New early Ford master arrived the other day; the stroke measures out at 1-3/16".
  7. Rocky
    Rocky
    Classified Editor
    I can't wait to see how you handle your throttle linkage conundrum. I have a totally non traditional 70s cable that's unreliable, ugly and tends to bind. I also have the same Ford pedal and linkage as you but like yours, it comes out on the wrong side of my carburetor.
  8. Tim
    Tim
    from KCMO
    awesome! I’ll compare those numbers and post them tomorrow :)
    Yeah I ran tw or here different cable set ups on the 46’ until I cut up the stock stuff and made it work. We just moved the arm to the correct side. So it looks more like a T than a Z but maintains all the stock angles and ratios.
    how ever this inliner has the carb way further led than a v8. I’ve got a couple ideas, I’ll post as I figure it out for sure.
  9. Tim
    Tim
    from KCMO
    Snuck a little time in tonight C43BA80C-E71A-4B42-BC56-C33396EBDD2D.jpeg always like looking at this while it’s got the hood and cowl off. Feels Like a real life cut away drawing 6A22B7CD-F065-4DD6-B444-A848DE999916.jpeg BDA86AD1-128B-4F37-AA5D-CF7F125353DB.jpeg a little hard to see but I stuck a sheet of card board on where the kick panel would be with a magnet. Seems like I should have room for my foot on the clutch with out any issues.
    also measured on the cowl top and I need to trim the edge where we removed the tank for the upper left hand corner of the pedal box. Glad I like the pedals where I mocked them up because I’m not sure if you could really move them over any further.
    going to go buy metal for bracing the firewall and filling the dash in the morning. I don’t think I’m going to really going to have time to get started on the bracing after doing the dash but I figure if I’ve got the metal laying there then it’s that much easier to go ahead and start in on it when I get a little garage time.
    Keep ya posted
    kidcampbell71, Stogy, Thor1 and 4 others like this.
  10. Tim
    Tim
    from KCMO
    Bought hotrod parts this morning :) 92F5D420-0D71-499B-A4AF-9564B41808A4.jpeg
    kidcampbell71, OFT, JOYFLEA and 6 others like this.
  11. Tim
    Tim
    from KCMO
    BE7A2C66-DBEF-4828-BB60-7C37494B899F.jpeg Uh yeah @Tuck got a pull max and some louver dies made and now I’ve been day dreaming the length, size, spacing, rows of louvers for hood sides
    But wait! 39794C96-52D8-4E12-88F0-4373A6375B49.jpeg ****! That’s the sound of my mind being blown.
    probably gonna need some of that! So cool!
    Stogy, brEad, drdave and 4 others like this.
  12. Six Ball
    Six Ball
    from Nevada
    Tell me more please. I have some sections of 90lb railroad rail that I'm sure could be put to use in building a louver press big enough for anything you could drag to it. That backing plate looks cool!
    JOYFLEA, Stogy and loudbang like this.
  13. Tim
    Tim
    from KCMO
    That’s about all I know. He’s been posting all sorts of long and short louvers on Instagram playing with spacing and ect. I’m sure he’ll chime in eventually
    Stogy, brEad and loudbang like this.
  14. Austin kays
    Austin kays
    loudbang and Stogy like this.
  15. Tim
    Tim
    from KCMO
    Right?!?
    loudbang, Stogy and Austin kays like this.
  16. Tim
    Tim
    from KCMO
    Alright so made the template for the dash filler tonight
    515DF5F0-969B-4BCC-ACED-95CA2BF4E686.jpeg 8BE0780D-4F6C-46D5-B83C-834BF38E5023.jpeg 46A0FB5D-009F-45DC-BE2B-08E1A218578A.jpeg
    Cut out the side of a frozen pot pie box and took my first swing. I traced the piece I cut out of the dash but it didn’t match up very well
    try 2 I shoved the new square of cardboard inside the tank and traced the edge. Worked way better.
    cut it out and test fit it. It’s a little on the big side. I think I’ll cut the 18g to that perimeter and then sneak up on the figment.
    0B8F5DCB-8779-4D48-AD38-E1F1F06E36F9.jpeg 5C6F8439-27A4-4AE6-9569-C586A931AA90.jpeg 4FA7A848-08C9-4CC4-B82B-83644C455093.jpeg
    peak of the spare cowl pieces and tank stuck together with the bracing pieces laid out 724ACA0C-2006-4C7B-A0E7-F747C29F2CF6.jpeg
  17. brEad
    brEad
    OFT, loudbang and Tim like this.
  18. Stogy
    Stogy
    He's quite the Hamb Talent...his roadster is beyond Wild and lots of inspiration to be gleaned...
    Happy New Year Tim...there's a louvered cover I've seen a couple of times that you'll find interesting I saw. I'll post it when I find it again because it did happen...:D
  19. Tim
    Tim
    from KCMO
    Trimmed it to fit with a tight **** weld and test fit a few times.
    Normally id paint the metal white and mark with a pencil so the line is easy to see but was in a rush so I used tape. Lined it up to use up the lease amount of metal and used one of my strong magnets to hold the template down/still
    7ACA45EC-CF61-4F80-A5D0-C92093D66C39.jpeg The magnet is inside the glove, then when it attracts metal shavings and dust I can just fold the glove off F136A57C-7B6A-41FB-9F35-232F0E55D630.jpeg
    Now can I get it cut out before we have another baby?
    stay tuned lol
  20. Tim
    Tim
    from KCMO
    Well no baby yet but I’ve got this cut out and to my buddies shop to have him slowly weld it up for me. 8592BE7F-E100-4C51-A3EB-0657B2CA1197.jpeg all the clamps were going to be in the way of the saw so I used a chunk of track on top of a clean piece of lumber to hold it down. 4890E995-5FA9-4244-A3AD-BA9EF04834AB.jpeg not as dead on as I’d have liked but should work just fine.
    while he’s messing with this I’m going to start on the cowl/ firewall bracing.
    might sit the hood on the car minus the cowl just to make 100% sure that the masters should clear. That outside corner with all the tapering hood lines always makes me concerned
    Stogy, loudbang, Thor1 and 1 other person like this.
  21. Stogy
    Stogy
  22. Tim
    Tim
    from KCMO
    It will look different but that’s basically been the plan. A louvered cover that takes a quarter turn fastener to attach
    drdave, Stogy and loudbang like this.
  23. Tim
    Tim
    from KCMO
    I really don’t like when things move from mock up.
    I scribed a line on the edge of where the box is sitting on the firewall flange. I measured it from a point that will not move and I made a small witness strip as well. EAA9800F-C17C-4B23-A783-5F4D8C10140A.jpeg CBA81E4C-9D37-43F7-AB43-7C4F49EF5D4B.jpeg CC66D911-5C32-4B45-AF46-D9E181596261.jpeg
  24. Tim
    Tim
    from KCMO
    Stroke for the 1” bore wilwood master is 1.43 or 1 & 7/16
  25. Tim
    Tim
    from KCMO
    I found the listing for volume for the smaller bore units as listed in the photo but could t find the 1 inch information
    osage orange and loudbang like this.
  26. Tim
    Tim
    from KCMO
    Those last two posts are for @RICH B who had been asking about that sort of thing, just took me a minute to get around to it
  27. I don't have any pics but of mine, but I was setting it up to run a car/truck gas pedal and a backwards arm. I have two different length arms (I think a V8 and a 4cyl), so different length sleeves and extra bell type mounts (like yours). I was going to run the arm over the top of the steering column (instead of the stock towards the p***enger side) and make a rod that goes through the firewall to the carb (using the stock ball ends). Or you can run it outside the firewall if your firewall has a dip in it. I pulled off the s**** pedal and was going to just put it on backwards (reverse it). Does that make sense?.
    I have one like this and a longer shaft one:
    Basically making it look like this and just flip the pedal around:
    Here's another way:
    https://www.jalopyjournal.com/forum/threads/tech-week-ford-s****-throttle-pedal-update.1070843/
    drdave, loudbang and Tim like this.
  28. Tim
    Tim
    from KCMO
    Hey that’s an idea! I’ll mess with mocking that up when I get a minute. And I’ll check the link you shared after dinner :)
    I wonder if the return spring on the pedal is sufficient if your linkage is all solid rod and no cable, or if you should still have them on the carb.
    the 46 ended up with no spring on the pedal and two springs on the carb.
    @Rocky any thoughts on that?
  29. flatout51
    flatout51
    I'm running the spring on the pedal and its plenty. But I'm also running the springs that go around the throttle shaft of the stromberg carbs. So I technically have 3 springs.
    Sent from my SM-G977U using The H.A.M.B. mobile app
  30. I was going to run a spring on the carb also. My ‘47 has a carb spring also.
    Tim and loudbang like this.
