Projects Timm builds a model A
Discussion in 'The Hokey Ass Message Board' started by Tim, Mar 8, 2016.
  1. 31 Coupe
    31 Coupe
    I use one of these 1000 Litre (~250 Gallon) plastic chemical tanks for my mol***es mix. Carefully cut out the top and fit rubber strip overlays. They allow you to fully dip bigger pieces, usually can get them here for ~$100 or less.
    Six Ball, drdave, loudbang and 2 others like this.
  2. -Brent-
    -Brent-
    @31 Coupe we call them IBC totes. They're great and not all that expensive.
  3. Tim
    Tim
    from KCMO
    @31coupe @-Brent-
    that’s not a bad idea! My friend usually has a bunch at the shop, they heat during the winter with used motor oil and store it in those I believe.
  4. Tim
    Tim
    from KCMO
    For anyone wanting to snoop further this is what I’m using 9CFCD156-E674-4C2E-9D86-1DFEBEBDB22E.jpeg 5239E95F-7685-4C61-986E-0DE7F38CAD6F.jpeg 68848626-F33F-4F39-AECB-A1D5AFA60FF9.jpeg
    Thor1, kidcampbell71, brEad and 6 others like this.
  5. Tim
    Tim
    from KCMO
    054E455E-7091-4FFA-9D5C-00BD47907178.jpeg DACD95AF-B5E2-4DE4-BB23-567217EE5096.jpeg 48 hours in the pool and you can tell the mixture was weak and settled in some areas more than others but it’s good enough for cleaning things up for storage/ banging on. AF8D02D4-DD3C-42A1-A339-7FAF6F70AC5B.jpeg
  6. Tim
    Tim
    from KCMO
    The silver wheel has one bent spoke and the inside is crusty but in the photo where it sat in better stronger acid you can see the white line where the fluid level was and the almost
    Magnesium color of the “clean” metal so I think it’s not as bad as it looks.
    lots of grease on that one as well. I didn’t make any effort of cleaning them before dunking them so I think a wire brush and an afternoon and they’ll clean up.
    though I’m wondering if I shouldn’t cut bait and find a better one.
    9F015B0A-EFB4-499D-9095-5CA46CB7839C.jpeg ED7FE631-7BBD-427F-82CA-0489602084A0.jpeg
    guess time will tell. I rinsed them with dawn dish soap and 20 gallons of hot water instead of the hose and sprayer because it’s in for the winter. I’ll mess with them laters just wanted them cleaned up some before they land under a work bench or on a shelf
    Thor1, kidcampbell71, brEad and 5 others like this.
  7. Tim
    Tim
    from KCMO
    Was gonna wait til I had it
    In hand but I’m to excited. Header is smoothed painted and ready to bolt back on.
    i had a 9-10 year old can of high heat paint and after painting it found that it wasnt drying. Trying to sand a run out it just gummed and pilled up. So it all got taken back down to metal, smoothed some more little spots that bugged him and painted with a new can of paint.
    Can wait to see it together :) E841E51F-8AB0-4D4F-B338-1C179C9ABBFB.jpeg
    redzula, kadillackid, Thor1 and 8 others like this.
  8. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    @Tim, I remember tuning into this thread when you started it, and now it's super cool to revisit it with fresh eyes. I'm now subscribed so I won't miss a beat :)
  9. Rand Man
    Rand Man
    Ya done good Tim.
    loudbang, Stogy and Tim like this.
  10. Tim
    Tim
    from KCMO
    Thanks guys.
    @J.Ukrop its been awesome watching not only your build but how the content you’re producing is shifting along with it. It is noticeably better in my eyes. Your roadster is going to be awesome!
    Thor1, loudbang and Stogy like this.
  11. dumprat
    dumprat
    from b.c.
    @Tim how are you going to attach the rest of tmy he exhaust? Clamp? Weld on? I don't see a provision for that.
    Thor1, loudbang and Tim like this.
  12. Runnin shine
    Runnin shine
    Tim when I spray on the POR surface etch it even eats a little of the leftover rust that my mol***es didn’t get if I didn’t leave it in long enough.
    I’m using a 50gal plastic garbage can on my grill shell, garnish moldings and a bunch of smaller stuff.
    Stogy, Thor1, loudbang and 1 other person like this.
  13. Tim
    Tim
    from KCMO
    bailing wire ;) it’s traditional.
    No, not really. Lol. I’m going to cut a triangle ish flange out of 1/4 plate. I’m going to add it when we do the rest of the exhaust figuring there could be a slight tweak to the flange that would make life easier so we’ll wait to mock up head pipes before adding the flange.
    I also want to fully mock the section up to make sure the flange is clocked in a way that I can actually get to the bolts
    Stogy, Thor1, brEad and 2 others like this.
  14. dumprat
    dumprat
    from b.c.
    Hahah!
    That reminds me, I am running low on baling wire.
    Stogy, Thor1, kidcampbell71 and 3 others like this.
  15. Six Ball
    Six Ball
    from Nevada
    It really screwed me up when they went to the colored twine. Bailing wire fixes are a folk art. My friend wrote a song named "I'd like to Thank the Guy Who Left the Bailing Wire Hanging On the Fence". It got him out of a bad situation. :D
    Stogy, loudbang, Thor1 and 1 other person like this.
  16. Tim
    Tim
    from KCMO
    Haha yeah orange twine just isn’t the same
  17. grumpy gaby 2
    grumpy gaby 2
    Yea I have trouble getting the orange stuff to stick in the right areas! My previous baler was wire tie, have two new rolls of it........If I could only remember where I put it!!!!!!!!
    Stogy, Six Ball, loudbang and 2 others like this.
  18. Six Ball
    Six Ball
    from Nevada
    When I was a kid our old bailer had a long tube with straight pieces of wire in it and you pulled them out and fed them by hand into the machine. It took one person to drive the tractor that pulled the bailer and two people to run it.
    I've seen some very colorful things made of the twine reminiscent of the horse hair hitching technique , belts, suspenders, hat bands, headstalls, halters.... Give people material and they'll make stuff.:D
    Stogy, brEad, Thor1 and 3 others like this.
  19. Tim
    Tim
    from KCMO
    Seen more than a little bit of a ford truck held together with it lol
    Stogy, Thor1, Six Ball and 1 other person like this.
  20. Tim
    Tim
    from KCMO
    Sneak peek :)
    Tman, OFT, loudbang and 5 others like this.
  21. Six Ball
    Six Ball
    from Nevada
    Very nice! What kind of clearance do you have to the steering box? Don't forget the Ford/Miller Indy cars. :eek::D
    loudbang, Stogy, Tim and 1 other person like this.
  22. Thor1
    Thor1
    Tim,
    The header looks great! A really well thought out design with good execution.
  23. Tim
    Tim
    from KCMO
    @Six Ball yeah my 46 is super tight and it’s been ten years so I kinda gauge what kind of space I really need off that and @flatout51 model A because he did actually lock his up on the way to the drags a few years ago.
    it actually had a primary touching the steering tube close to where it sleeves over the box but by the time the pipes were “m***aged” and convinced to fit the collector ive got st least a 1/2 inch clearance. Should be plenty
    edit:
    the 46 is close to the box directly where this is the tube/ mast mostly and quote far from the box itself. I’ll measure later
  24. Tim
    Tim
    from KCMO
    Closest the two forward primaries come to the box is at the bend where they turn towards the rear of the car. The close one is at least an inch behind the box and the second closest is 2 inches back and an inch over. So probably 2 inches away diagonally/ as the bird flys
    Stogy and Six Ball like this.
  25. Tim
    Tim
    from KCMO
    Got the intake on with two nuts. I’ll need to see how the bolts and hold downs need modified for the rest of the holes now B68301BA-5A29-46D5-A932-ABA790BA0497.jpeg 8342C644-0FE6-4CBB-989E-F4C96A784F7B.jpeg 550F963C-9BB4-4680-9618-34AFAE4B46CE.jpeg 982D8B50-75B1-4968-9141-646E1148CF05.jpeg 03AAE577-2903-4784-8ECF-636A6BADE239.jpeg AB0B1D87-3460-4727-AA2E-D359E95D0C37.jpeg
    kadillackid, OFT, drdave and 6 others like this.
  26. Six Ball
    Six Ball
    from Nevada
  27. brEad
    brEad
    I like how you have the primary tubes parallel with the steering shaft. Looks great!
    loudbang, Thor1, Tim and 1 other person like this.
  28. Tim
    Tim
    from KCMO
    Thanks guys I’m pretty pleased with it. Got a good scuff in the paint from something dropping on it but it’ll need some paint when we weld a flange on anyways so I’m not to upset about it.
    onto the next step... which should probably be go replace the voltage regulator in the 46 so I can drive to work lol
    Stogy, brEad, Six Ball and 3 others like this.
  29. Tim
    Tim
    from KCMO
    3D0A5BAF-B27C-42C4-BE2C-EB4DCD73EC2C.jpeg While @Austin kays Is building inventory for his old ford factory I spotted this in a photo!
    early A side spare frame mount! I called dibs now I only need another arm and I’ll have the set for the car completed :)
  30. Tim
    Tim
    from KCMO
    Thinking about trying to shove the 46 and the A next to each other in one stall so I can have some shop space back over the winter. Parked over towards the center and mocked up a grill and wheels. I know if I put both cars on Dolly’s they fit but I need to be able to get the 46 out with out moving it on Dolly’s or moving the A
    hopefully have it out in the next week or so and I’ll try it for real... with a parking spotter though lol AB8ACFFE-6D2B-4F39-8806-53039BF865AB.jpeg
    Stogy, guthriesmith, brEad and 4 others like this.
