Projects Timm builds a model A
Discussion in 'The Hokey Ass Message Board' started by Tim, Mar 8, 2016.
  1. Six Ball
    Six Ball
    from Nevada
    Last Saturday I saw an estate sale at a place where I got a lot of Chevy pickup parts several years ago. While checking it out I saw an OMC boat motor and didn't think much about it at the time. I have a couple of extra 153s. Later I thought it might be a 181. I went back today about 15 minutes late. I was a 181 and a guy I know had just bought it. Damn that's 20 free hp.
  2. Tim
    Tim
    from KCMO
    Kinda like when you get angry when that car you weren’t going to buy online gets sold lol
    drdave, loudbang, Thor1 and 1 other person like this.
  3. Six Ball
    Six Ball
    from Nevada
    Exactly! I don't need one and I have everything to put my 153 together except the drive.
    loudbang, Thor1 and Tim like this.
  4. Tim
    Tim
    from KCMO
    078ECAC5-F1FF-4414-A43D-973E2C7C7812.jpeg Well I pulled the rock hard hose and clamps off to sit the hat down on the carb and see just low I could actually get it.
    A264BCFB-A0B5-4C71-8753-349157392EBE.jpeg 7442F361-710B-4D47-8BDA-D766B5F36F93.jpeg Little more mock up, sit and stare. Partially trying to see what the minimal slice and dice route to making it look better is. Even from the p***enger side you can’t really see the back half. But I know it’s there. You know how that works.
    anyhow I did also find that I have another broken lid that is the same ish diameter as the breather top so if the larger breather fits I would t have to start all over. I’ll mock it up this week a little better. I need to raise the top half to line up with the carb hat and take a look at that as well. I don’t want to have a jog in the pipe connecting the hat to the breather because it seems like it would be visually distracting. At the same time I think the top of the breather being even with the top of the valve cover is the best look.
    always a compromise somewhere I suppose.
    also need to find an easier to search list of Round air filters. I want to make sure I don’t create a cavity for a filter to fill and then not be able to find a filter that size
  5. drdave
    drdave
    I think you are on the right track, a little tweak here and a little tweak there. Still working through bugs on my Chevy and the new rear carb didn’t have room. Smaller booster, a divot here, a trim there, shave this, wiggle that....it’s finally on. I’m confident you will get there with a result you will be happy with
    brEad, Stogy, loudbang and 3 others like this.
  6. Tim
    Tim
    from KCMO
    Mock it up with the inlet/outlet on the same plane. I think it’ll work. I’d like the whole thing to sit lower but it is what it is. I could make the section between the bend and the top of the filter housing longer but it kinda kills the nice flow it has. Long as it clears the hood side I think it’ll work fine. EDF2D406-E26A-4BBC-A24E-DAAE8EB3CBEC.jpeg CE69B006-860C-4673-98F0-9B7E81F1218D.jpeg I also found a good off the shelf filter via searching summit. I’ll get one before I cement it all just to be 100% sure it all works right 9A594298-AC79-4111-A298-B87958CB4FBA.jpeg 41E9ACAB-A8DD-42E3-985A-8EAF8234CF18.jpeg
  7. Tim
    Tim
    from KCMO
    Also seeing metal prices go up I took advantage of a slow afternoon at work to drive over to metal by the foot and pickup metal for every project that I’ve measured for including making a new bottom half of the air filter. The pot lid worked at the smaller size but at this larger size it just does t work for me. I’m going to make an mdf buck and hammer a lower out of 16 g sheet 2C0BDB3F-1C31-40BC-9DCF-F417D9E6CFC6.jpeg A2F865A1-52A8-4618-80B8-635FEE386EF0.jpeg 3D4EA980-59AB-4C26-B641-43618272D2A6.jpeg
    kidcampbell71, brEad, Thor1 and 4 others like this.
  8. Tim
    Tim
    from KCMO
    There we go, couple bucks and they cut everything to my measurements quicker than I could walk to the loading dock.
    5961D8F4-28A8-47A4-B37F-1FBDF62D4E08.jpeg 0765ADAD-7973-4FC9-BCE5-EFB570413E5F.jpeg
    Enough 16g sheet to build the rest of the air cleaner and patch the running boards. Rectangle tube for new running board braces, door sills and b pillar supports, strap for license plate mount and some round tube to make jigs out of.
    should be set :)
    kidcampbell71, Thor1, drdave and 3 others like this.
  9. Six Ball
    Six Ball
    from Nevada
    Getting that under the hood reminds me of my son and I putting the supercharger on his '54 Stude and getting the stock hood to close. The wagons & sedans are 4" shorter than the coupes from the firewall to the radiator. When they put the McCulloch on them they added a hump in the hood and fins and called them Hawks.
    Nice clean steel, so nice to work with.
  10. Tim
    Tim
    from KCMO
    I was just thinking today that if you didn’t know anything it would look like forced induction at a glance. Haha.
    That car is awesome , love when you post photos of it
    Stogy, Thor1 and loudbang like this.
  11. Tim
    Tim
    from KCMO
    Started marking my buck for the air cleaner bottom 9576F1F9-02F0-4E50-AFFB-57BFC4CAB6F8.jpeg looking around the house I found several table leafs for tables we haven’t owned in years.
    this one was wide enough so I started roughing it out.
    my plan is to cut the squares out with a chop saw and then keep cutting corners until it’s mostly round. Then hit it with a jig saw, bolt them
    Together and make them match with sanding or what ever is handy.
    One will end up a tiny bit flat on one curve because I didn’t account for the blade width of the chop saw in drawing this out but I had been back and forth on making the top of the buck slightly smaller so I could get to the corner a little easier anyhow
    loudbang, Six Ball, Stogy and 3 others like this.
  12. Tim
    Tim
    from KCMO
    Also ran the numbers after thinking it didn’t look quite right and this is an f1 truck clutch arm. Still long, still gonna cut it up to make it work just right. Just thought I’d do***ent it for the sake of having a note for when someone asks in ten years what it is and I don’t remember E02C28F1-1CC0-4ECA-AFC7-88F683A82060.jpeg
    drdave, loudbang, Thor1 and 4 others like this.
  13. Tim
    Tim
    from KCMO
    Very hi tech over here. E118A7E3-924D-414B-9018-D3FC5BACAAEF.jpeg 0186DB95-B0E4-4758-9DD3-74636CC0FD34.jpeg 5F0C2700-E66F-44DD-BF4F-C262575E305B.jpeg 5D28AD9A-6AFA-481D-97BD-FAE72ADACE79.jpeg
    there is a slight bow in them but because they were cut right next to each other they nest just perfect In each other.
    im not sure that it’s enough to put any crown in the finished product but if it is I don’t think it will be visibly noticeable and could get rid of any possible oil canning so I’m fine with it.
    should be able to center drill, bolt together and then smooth them out with some rough sandpaper pretty easily.
    trying to figure out how much overlap I need for the flange so I can cut it out and not have to trim a crazy amount off after forming g
    Stogy, drdave, loudbang and 1 other person like this.
  14. Wish you were closer, I have some AKDQ (drawing quality) steel that forms beautifully
    Stogy, loudbang and Tim like this.
  15. Six Ball
    Six Ball
    from Nevada
    A couple of years ago my son & I picked up a lathe from a sheetmetal shop in California. The young guy that ran the shop was using it to turn round shapes over wood bucks. It was really cool to watch.
    Stogy, brEad, drdave and 2 others like this.
  16. Tim
    Tim
    from KCMO
    @Six Ball that sounds cool.
    I love watching videos of making “spun” metal
    Parts
  17. Tim
    Tim
    from KCMO
    Little progress this morning C5F1B747-0A7D-41BA-A934-E1874AD5BBB4.jpeg got them drilled 1040BC75-A8DC-4AEA-8D9B-F8C1A8905D4C.jpeg bolted together with an indexing mark 00F6E069-E45E-428C-84B6-7520AE2AB1E8.jpeg put a fat washer on one side thinking I should add one to the other as well 483B3231-A09A-4100-A5AF-87038FF95DA2.jpeg hand file is knocking it round pretty fast. Probably stick some 60 grit on a sanding block to get the last bit. Not hard making it match the penciled line but keeping the width flat/square takes more attention than I thought it might.
    easy stuff to chip away at either way
    drdave, loudbang, Stogy and 1 other person like this.
  18. Thor1
    Thor1
    Tim, if you know someone with a belt sander I would encourage you to ask them to hook you up. It will make your work go much faster, the sanding will be smooth and well controlled, and from my experience it will be much easier to keep the width flat and square to the faces.
    drdave, loudbang, Tim and 1 other person like this.
  19. Stogy
    Stogy
    If you have any drill press/guns you could chuck the center stud and tape the trigger to an rpm your comfortable with and gently clamp in some cardboard/cereal boxboard or a thin cushioning shipping foam and file/sand.
    That brings in a new dynamic in be careful over the non rotate method that works and can give more than adequate results...I was just thinking out loud...you can use bigger bolts if desired as well of course...
    Six Ball, loudbang and Tim like this.
  20. Tim
    Tim
    from KCMO
    Belt sander would be handy! This is actually going pretty quick, and to be honest I tend to like doing the tedious hand tool route on most things.
    thinking I should be ready to hammer on it this weekend.
    drdave, Thor1, Six Ball and 2 others like this.
  21. Stogy
    Stogy
    I made a circular top for a stand from 3/4 plywood recently and did pretty much what you did...and it took a while...I used a table saw to rough it to a circle and files, sandpaper and a vise for the rest...
    Thor1, Tim and loudbang like this.
  22. Tim
    Tim
    from KCMO
    Cool!
    Most of what I need to knock down is 1/16” tall and not very wide. Thankfully I have plenty of experience making a circle with straight lines so I got it pretty dang close. I’m focusing mainly on the half the metal will draw over because the top is just holding it in place.
    Thor1, Stogy and Six Ball like this.
  23. Stogy
    Stogy
    I can't wait to see that metal wrapping around that buck/form. So are you just going to shape the flange around the buck via hammer...I may have missed that...I was thinking of a female die and a arm-strong or hydraulic press...but as always what's in the Shop governs direction...I have neither myself but sure have utilized them in the workplace and know of the capability they possess...
    loudbang and Thor1 like this.
  24. Tim
    Tim
    from KCMO
    I’ll hammer it over using a variety of hammers and s****s/ *******s. Whatever feels right.
    then hammer/ dolly any additional wiggles that show up after prying it off the buck. I’m thinking a think cut off disc to trim the flange to a shorter uniform height.
    Or possibly a hand saw with it still on the buck.
    guess we’ll find out!
    loudbang, Stogy and Thor1 like this.
  25. redzula
    redzula
    I think I already know the answer by so you have a take l table saw? There is a way to make perfect circles by using a pivot hole I. The middle. Si ce you need a hole in the middle anyway for the finished part and to bolt the hammer for together.
    Sent from my SM-G781V using The H.A.M.B. mobile app
  26. redzula
    redzula
    Tman, drdave, loudbang and 5 others like this.
  27. Tim
    Tim
    from KCMO
    That’s clever!
  28. Stogy
    Stogy
    Dayuum, learn a new thing everyday...I gotta make me one of those...thanks @redzula for the tip and you @Tim for p***ing the buck...:D...Hamb Gospel I say...;)
    loudbang, Six Ball and Tim like this.
  29. Tim
    Tim
    from KCMO
    Little photo dump catch up. Wanted to wait til I was done but this is close enough for an update AA5CBF38-8E64-493E-B1B1-6442E70DA9A6.jpeg AC91DF8E-5905-4518-A074-01F8AB251D7A.jpeg 672577F2-7476-488D-A169-342C58F1F232.jpeg 3CEDBD17-CEC5-4703-BD67-2C9B0FE59AEA.jpeg 211B349C-1CAC-4E80-B9E7-0DDBD631F8F7.jpeg 46C05477-B9EB-485B-913D-E6AF84007760.jpeg A223C645-C0F7-46D6-A29C-E655B7173599.jpeg 5CE68FFC-1FFB-4B51-BA5E-9C367057AC1B.jpeg 47A71D45-DE55-4485-96B5-CB98B0C5ACD2.jpeg D2EF5AD0-4CE0-485A-96FA-5F6E25CA16D3.jpeg
    brEad, Shadow Creek, loudbang and 4 others like this.
  30. Not bad for a first try.
    loudbang, Stogy, Thor1 and 1 other person like this.
