My friend Timm's 27 on a model A frame, 32 K member, 38 engine, 39 trans, 40 rear, 32 Mor-Drop front, and 40 brakes with 35 wires. Ch***is pics to follow.
Timm's front axle is a 32 Ford heavy with a 4" drop by Mor-Drop. The 33 wishbones were modified using a model A yoke giving a little more pan clearance. The 32 Ford K member was modified and installed using rivets by Vern Tardel. It will use 32 ford brake and clutch pedals. A 40 Ford rear end will have a T spring mounted on top.
