Technical Tip # 73!
Discussion in 'The Hokey Ass Message Board' started by brigrat, Jan 6, 2017.
  1. brigrat
    brigrat
    from Wa.St.
    Spent way to much time trying to get a flat wash, lock washer & 3/8" nut on a hard to get to '36 Ford body mount bolt, just room for couple fingers. Got out my semi powerful magnet and what do you know it held the washers on till I could get the nut started. I know, it didn't happen without pic's! Proof a magnet is stronger than gravity in some cases.................................
    wraymen, 117harv and Surf City like this.
  2. DukeCity41
    DukeCity41
    I have used masking or duct tape.
  3. timwhit
    timwhit
    Great idea!!! I had the same issue with my '34 where the X meets the side rails. Tim
  4. brigrat
    brigrat
    from Wa.St.
    DukeCity41, On a vertical bolt the tape would of had to be magnetic!
  5. wraymen
    wraymen
    Very cool, my son thought of that too when we were putting the bed back in my 50 Chevy. Worked great.
  6. David Gersic
    David Gersic
    from DeKalb, IL
    I had a bolt going through the firewall. I could put a wrench on one side, or the other, but couldn't reach both at once. I zip tied a wrench to a magnet, stuck the magnet to the firewall, with the box end holding the nut, open end braced against the master cylinder, then crawled under the dash to tighten it up from the inside.
  7. Texas Webb
    Texas Webb
    A magnet is a good 3rd hand.
  8. blowby
    blowby
    from Nicasio Ca
