Tip for cleaning rusty chrome
Discussion in 'The Hokey Ass Message Board' started by 1952henry, Aug 8, 2012.
  1. 1952henry
    1952henry
    There's been many ways written about how to remove rust from chrome, steel wool, etc. For those who haven't tried this, do yourself a favor. Easily removes rust from pitted chrome. Doesn't take much elbow grease to boot. You may find it in a boat shop, otherwise you'd have to order it like I did.
    http://www.collinite.com/automotive-wax/liquid-metal-wax/
  2. CocaCola and a ball of aluminum foil.
  3. Yup......Believe it or not it works
  4. Jimbo17
    Jimbo17
    Citric Acid also seems to work.
    Thanks for the tips thought and I will give it a try.
    Jimbo
  5. RagtopBuick66
    RagtopBuick66
    I've had pretty good results with Mother's polish and a little bit of fine steel wool.
  6. I believe it, thats why I posted it :D
  7. 49ratfink
    49ratfink
    I like SOS pads.
  8. low budget
    low budget
    from Central Ky
    x-2
  9. chubbie
    chubbie
    now its all scratched:confused:
  10. twistedridez
    twistedridez
    Speedy Metal Polish
  11. low budget
    low budget
    from Central Ky
    The stuff mentioned may be better but I have never had a problem with noticable scratches when using wet soap pads (SOS pads) but usually the stuff I use em on is pretty bad and can only look better.
    Ive used them on old wheels and bumpers etc. for years and have had pretty good luck.
  12. Thorkle Rod
    Thorkle Rod
    SOS pad, well lubricated and, then cleaned and followed by, Turtle Wax Chrome Polish. Has been working since I was a little puppy in 1957 polishing the chrome fenders on my used Schwinn I bought for 50 cents from Bobby Abernathy.
  13. drptop70ss
    drptop70ss
    from NY
    SOS pads always, brillo pads never.
  14. LZ
    LZ
    Im an old SOS pad Turtle wax polish myself.
    But Collinite products are just the best. Use them all the time on the Boat. Hard work but season lasting results. Have to try the stuff sometime.
    Also as mentioned for fine work Blitz and the like.
  15. 1952henry
    1952henry
    I should mention I use the wax and a cotton cloth. Then a clean cloth to buff it out.
  16. Hotrod1959
    Hotrod1959
    000 steel wool and windex followed with chrome polish works for me.
  17. 53catalina400
    53catalina400
    from Mebane,NC
    Eagle one also has a silver can with oil soaked wool
    cant remeber the name right now but i have always had good luck with it
  18. 1931modela
    1931modela
    from montana
    Windex and .000 steel wool
  19. J'st Wandering
    J'st Wandering
    Nevr-Dull or something like that.
    Neal
  20. Bull
    Bull
  21. Rusty O'Toole
    Rusty O'Toole
    Copper scrubbing pads (they don't scratch) and Pledge. Follow up with Simichrome, Flitz, Autosol or your favorite polish.
  22. Rickybop
    Rickybop
    Solution of molasses and water, about 1:9 ratio will remove the rust from anything and not harm the metal at all. Takes a couple weeks of soaking though, followed by power washing.
    Watch this. Works good. http://www.youtube.com/watch?v=KZCFcxf5IBw
  23. chubbie
    chubbie
  24. Clik
    Clik
    I used to make a set of rusty chrome wheels look pretty damned good by wiping Navy Jelly on them, cleaning them off and then painting them with chrome paint; but before the paint gets tacky wipe it off lightly. It will wipe off off the good chrome but stays on the bare metal spots. You'd be really suprised at what you can save. It won't pass a show judge but is perfectly streetable.
  25. 59wood
    59wood
    from Dago, CA
    Deluded CLR with water and .000 or .0000 depending on how heavy or light the rust your cleaning. Follow with your favorite metal polish.
  26. damagedduck
    damagedduck
    from Greeley Co
  27. Oxalic acid
  28. 56FRLN
    56FRLN
    I've been using this stuff for over 20 years - little bit of water and a toothbrush and it does wonders. Basically liquifies the rust and you wash it off. Wal-Mart and most grocery stores around here sell it.
  29. no55mad
    no55mad
    Lay down a nice film of lube (such as WD40) and then scrape with a cheap stainless steel bladed pocket knife. Follow up with some chrome polish.
  30. oakmckinley
    oakmckinley
    I just bought a set of old cragars for cheap.
    My question is how far is "too far gone"? I mean the lips are good, just rusty. When is the point when you can't mount a tire anymore??
    Thanks
