Tips for getting metal out of hole saws?
Discussion in 'The Hokey Ass Message Board' started by JPMACHADO, Apr 30, 2007.
  1. JPMACHADO
    JPMACHADO
    from Not Listed
    Sometimes when I use a hole saw to notch tubing or just create a plain hole in some plate, the metal plug gets stuck in the hole saw. Does anyone have a simple way to either prevent this or easily remove the metal? I'm sometimes able to use the slots on the side of the hole saw to get the plug out. Other times using the slots just jams up the whole thing more. Thanks
  2. OLLIN
    OLLIN
    what if you tack welded a nail onto it to pull it out..
  3. I usually just use the slots. Another tip for hole-sawing, I always drill a hole right along the radius of the hole being cut, so the chips can fall out, and use lots of lubricant.
  4. Mart
    Mart
    I normally keep a small electrical screwdriver handy and just work it out from the slots, alternating from side to side.
    You're right, though, it's not exactly easy.
    Mart.
  5. If you remove the hole saw from the mandrel you can use a small drift down through the center hole. Alternate tapping around the drilled hole in the slug.
    Charlie
  6. chaddilac
    chaddilac
    screw driver through the littel hole in the back...
  7. metwiz
    metwiz
    from Salinas CA
    Before you drill your hole drill two 1/4" holes next to the pilot hole. That way you can use needle nose pliers to grab the slug out of the saw when finished.
  8. Retrorod
    Retrorod
    I think metwiz wins the prize......it just tried it, it works, it's simple.
  9. Thanks Metwiz I'll have to try it that way next time. I used to cut speaker holes in car doors and HATED to get the slug out.
  10. I usually drill 2 or 3 holes and then remove the center drill bit and everything ususally come right out out.
  11. MercMan1951
    MercMan1951
    Silicone spray on the hole saw.
  12. yekoms
    yekoms
    Metwiz may win the prize for gettin' the slug out but, Richard D gets the grand prize for the chip release hole. My Pop showed me that long ago and it works great. Smokey
  13. Yeah, I invented that trick decades ago.:D Nah, I learned it here!
    [/INDENT]
  14. hilborn283
    hilborn283
    self tappping screw about an inch long.it will drill the metal,but not the hole saw,bottom out,and screw drive the slug out.it works amazing.
  15. metwiz
    metwiz
    from Salinas CA
    The chip clearing holes are only necessary if the material is thicker than the teeth on the saw. Also if you put a few around the I.D. of the hole instead of just one it works a lot more efficantly in removing the chips
