Technical Tips for replacing a 53/54 Bel Air hood.
Discussion in 'Traditional Customs' started by The Chevy Pope, May 4, 2024.
  1. So I never actually paid any attention to the hood hinges on my 53 other than to notice that apparently the original springs are in amazing shape because I had no intention of removing the hood. But the other day I decided I wanted to use the louvered hood I got off fastcar1953. I obviously figured out how it attaches. But any tips or tricks for the springs? So far only thing I've come up with is wedge paint sticks between the coils with the spring stretched. And made sure I had at least two people willing to help. Just not wanting to launch a spring or anything lol
  2. fastcar1953
    fastcar1953
    https://chevy.oldcarmanualproject.com/miscellaneous/hoodspring.htm
    I built a hood hinge tool once out of angle iron and a couple of big washers welded on the ends.
    No idea where it is now . lol:D
    measure a piece of 1 1/2 inch angle iron and on each end weld a big washer on. Spread the hinge out stick in spreader and clamp it with a heavy hose clamp. lower hood and remove spring. make 2 one for each side and leave them on till your ready to put hood back on.
    RICH B and The Chevy Pope like this.
  3. Definitely sounds easier than putting fifty paint sticks in each spring lol
  4. fastcar1953
    fastcar1953
  5. I do have a very high quality floor jack
  6. Tim
    Tim
    from KCMO
    Just un bolt the hood from The hinge and leave it attached to the cowl? Then you don’t need to bother at all with the springs when swapping
    Hoods.
    Just Gary likes this.
  7. What I do on most cars. Not really an option on 49-54 Chevy IMG_20240505_002328.jpg
    squirrel likes this.
  8. gimpyshotrods
    gimpyshotrods
    I have scars and bad memories.
  9. Oh I've heard countless horror stories since I bought this car. Hence asking for tips. But this hood is just too cool not to run. And be good practice for when I put my 54 together IMG_2024-03-11-16-13-15-932 (1).jpg
    Unkl Ian likes this.
  10. Rusty Heaps
    Rusty Heaps
    If you don’t want to make one, National Chevy ***ociation sells a hinge spring removal tool for a reasonable price, or at least it was 10 years ago. :rolleyes:
    The Chevy Pope likes this.
  11. Tim
    Tim
    from KCMO
    Are those top two not bolts? How is it held to the hinge?
  12. Hinge is two separate pieces. If someone was to undo the bolt to the hood without supporting the spring at the least it'd launch the spring
  13. Tim
    Tim
    from KCMO
    Can you stick a prop…. Say a big *** open end wrench between the sprung arm and the inner fender edge?
  14. squirrel
    The "bolts" are actually shoulder bolts, that the link pivots on. They're part of the hinge mechanism.
    pretty ****py design, from a service perspective.
    hrm2k and The Chevy Pope like this.
  15. Yeah actually part of why the hood has never been off the car despite me putting two different engines in it. A 57 283 when I got it in 2020 and the current 350. I just opened the hood all the way and pulled the radiator and slid the engine in lol
  16. And seeing as the bolts have been in place since 1953 they should be fun to remove. May order a set of spare bolts just in case lol
  17. squirrel
    they should just unscrew...but then, I live in Arizona, so I always say that
    Tim and The Chevy Pope like this.
  18. I'm hoping so. Arkansas is usually pretty good when it comes to rust(where this car came from) but a previous owner went overboard trying to "patina it". And one thing popular with Arkansas patina guys is to piss all over it lol. I'll start periodically hitting with pb blast. Still gotta get the louvered hood home and sand it out, prime both sides, and paint the inside before it goes on so I have time to soak it
    leon bee likes this.
  19. Tim
    Tim
    from KCMO
    I understood the bolts are pivoting shoulder bolts. My 46 ford is attached the same. But I can take them out and pull the hood off no trouble regardless of the springs being on or off. I’m not fluent in old chevy though
  20. Yeah on the sprung piece theres no stop to keep it from hyper extending without the hood
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    yup you need a special tool for removing the springs
  22. His hood swap seems kinda backwards lol. Like I would have been happy with the blue hood lol
  23. MCjim
    MCjim
    from soCal
    Start around 4:50 to see this guy's solution.
  24. 325w
    325w
    Use the tool. You can change the engine an trans by pushing the hood as far open as possible. Then tie it back with a rope to the rear bumper over rider.
  25. Why don't you change the hood and leave the hinges/springs in place. You don't have th change the hinges to change hoods as far as I know?
  26. Tim
    Tim
    from KCMO
    John I believe that’s what he wants to do but if you don’t use the proper tool to first remove the spring it’s gonna let lose when you remove the hood
  27. MAD MIKE
    MAD MIKE
    from 94577
    Can't unbolt easily/safely with the hood springs under tension. And the springs are aleays under tension, hood opened or closed.
    Hinges are a scissor type that uses the hood as the top bracket as well as the pivot points. Action is cantilever, unbolting sprung or unsprung idler arm will cause the hood to move unpredictably. And without a lot of finagling, hinge components will not readily line back up with hood bolt holes.
    Easier/safer to remove springs first then unbolt hood.
