tire and spindle id
Discussion in 'The Hokey Ass Message Board' started by twiebe, Dec 30, 2012.
  1. twiebe
    twiebe
    hello all,
    i am working on a front axle for my ih truck project, and picked up a pair of tires and spindles at an auction for $5 dollars. does anybody reconize them, or should toss them and buy new?
    thnx terry iphone pics 130resize tire.jpg sorry, cant seem to get pic bigger
  2. gimpyshotrods
    gimpyshotrods
    Not sure what it is, but it appears to have a broken upper kingpin boss.
  3. Mr48chev
    I'd say that it had been part of a home made trailer for a number of years and someone cut the spindle in two with a cut off disk to get it off the axle. Probably to save the axle. You can see where they took a torch to the brake drum that was probably stamped steel like a lot of early Ford drums were to only have the hub. A look at the other side will help guys tell more of what it is or was.
    It looks like a six lug wheel so it was probably Chevrolet or that is the direction I would look in. What is the wheel diameter?
  4. twiebe
    twiebe
    iphone pics o side.jpg thanks guys
    you guys r good! yes it is a six bolt rim. yes the top of the kingpin boss is broke. i thought it was factory split, but i looked again, and it was cut to remove it. yes it had been a 2 wheeled torch cart. size is 5.25-5.5-17. here is a pic of other side.
  5. alchemy
    alchemy
    A torch cart with wheels that big would be handy for cutting parts back in the woods or over the cliff. Better put those wheels back to their proper use.
  6. what were you planning to use them on? in your first post you said something about an IH pickup
  7. twiebe
    twiebe
    last pic of oldest and youngest boys.
    not exactly sure of the year of the truck. i think late 30s to early 40s
    the front axle is just tacked in place. i found the cab upside down in my bush when i moved here. it was is a mess, so i chopped it 6" front and 5" back of cab. still lots to do
  8. BJR
    BJR
    I smell a Rat!
  9. 31Dodger
    31Dodger
    The wires on the wheel are welded, so it is not a Chrysler product wheel.
  10. Heo2
    Heo2
    I think its chevy around 33-34
  11. Mr48chev
    A little hunting shows that they should be proper for 34/36 Chevrolet Masters and trucks.
  12. twiebe
    twiebe
    thank you all for the responses. I think i will put these aside and order proper ford spindles from speedway. yes, at this point it is a rat! its my first project so im "practicing" my dream car is next in que. hopefully it will make you all proud.:)(after its done of course)
