Hot Rods Tire Help for a '32 street rod
Discussion in 'The Hokey Ass Message Board' started by VinnieCap, Jan 26, 2023.
  1. VinnieCap
    VinnieCap
    Hello,
    A friend wants to purchase some new tires for his '32 4-door street rod. He has 15" wheel vintique wheels.
    Tire sizes he wants are (they are radials):
    165/80r15 front
    235/80r15 back
    Any idea if anyone offers that range of tires in the same tread pattern? What do you guys suggest?
    Thanks!!
  2. Fortunateson
    Fortunateson
    A Street ____? LOL
  3. Atwater Mike
    Atwater Mike
    With RADIALS, yet!
  4. Mr48chev
    Those sizes are available though your local tire stores Front = VW size but finding front and rear with matching tread and sidewalls might be a challenge as the big ones are pickup size.
    Funny think is that Michelin invented the radials in 1946 or at least perfected them and they have been in use in the states since the late 40's. The state patrol ran them here in this state in the early 60's because they would handle better and handle high speeds better than the bias tires that were available.
    rodncustomdreams likes this.
  5. pprather
    pprather
  6. VinnieCap
    VinnieCap
    Not sure I get the joke or insult from the first two replies. The car is a street rod, 350, auto. Don't most street rods run radial tires?
    Thanks to the other two replies. I appreciate the input.
  7. millersgarage
    millersgarage
    Street Rod on a Tradition Hot Rod forum
    Not sure I have ever seen a 80 series tire before
  8. catdad49
    catdad49
    Try Tire Rack, they list most tires. You can search by size, which makes it much easier as they also list the diameters. Good Luck, Carp.
    Joe Blow, 302GMC and Just Gary like this.
  9. Elcohaulic
    Elcohaulic
    Diamond Back, Mastercraft Avenger tires.
  10. nobby
    nobby
    nexen roadian ct8 185 r 15 - i think the apect ratio is 80
    nexen roadian ct8 215 r 15 - i think the aspect is 70
    commecrial van / pickup tyres
    7 ply
    same tread pattern
    have the commercial designation if putting them on a pickup
    low noise 71 db
    ideal on 6j front and 7j rear
    6j=7'' = 175mm = 5mm rubber each way
    7j = 8'' = 205mm = 5mm rubber each way
    excellent quality and priced well.
    if you manage to find the 7'' wheels with the deeper backspace or the extra 5/8ths positive offset, IF you happen upon a 59.25'' rear axle, the track widths front and rear are not that far apart - thats if you are using a 48'' wide axle with the cheeby rotors and not the mopar versions.
  11. A Boner
    A Boner
    Street Rods usually run round tires, especially if they are freeway fliers!
  12. lostone
    lostone
    from kansas
    I just bought a pair of 165/80r15 of off Walmart. Com. Had them on sale for 49.00 each shipped.
    Put them on a pair of 5" wide et 5 windows on my 31 tudor.
    rodncustomdreams and Packrat like this.
  13. rob-redm
    rob-redm
    LOL , Street Rod is not spoken here..
    Bandit Billy likes this.
