Hot Rods Tire Pressure
Discussion in 'The Hokey Ass Message Board' started by hd1084, Apr 19, 2022.
  1. hd1084
    hd1084
    Just installed these Firestone bias ply tires on the hot rod. Was just curious what air pressure you guys are running on something like this ?? Thanks.
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    I am running 20 lbs on the front and 25 on the back of two vehicles with those tires.
    Nice sedan. I yike it.
    lucky ink and hd1084 like this.
  3. Fogger
    Fogger
    If not driving your car regularly bump the pressure up to 40# to help negate flat spots. Then lower it when you drive. I run 24 in front with 5:25x16 and 22 in the rear with 7"60x16 Firestone bias plys. The Pomona Fairgrounds is 50 miles from my home and when I didn't air up the tires when not driving and left them at the lower pressure it took 50 miles to get them round again.
    Algoma56, SS327 and hd1084 like this.
  4. twenty8
    twenty8
    The other way around would make more sense. The fronts should have more pressure because the weight distribution of the car will be biased more towards the front. An under-inflated tire will generate heat and be more likely to fail, and it is usually fronts that do because they carry more weight and do more work with steering and braking.
    Just sayin'.......:)
  5. SS327
    SS327
    Less chance of rolling a tire off of a rim on a turn also.
    twenty8 and hd1084 like this.
  6. A model A has front/rear weight distribution that is almost 50/50. That being said I run 24 front and 22 rear. It helps a little with the steering and I want a little more grip in the rear.
  7. Ned Ludd
    Ned Ludd
    I recently had cause to look for the weight distribution of a stock A Tudor (for this thread). Data for an actual car, recently weighed, suggests about 45/55. The V8 in the OP's car should shift that to around 50/50. Though: what does a banger weigh, anyway?
    The principle of distributing tyre pressure proportionally to the car's weight distribution is sound, though. I use it on my DD, a light front-drive hatchback with a lot of forward weight bias. I run 38psi front and 23psi rear in the 50-series radials, which differs a lot from the stock specs. It tunes out the factory understeer nicely, and gives very even wear.
    Remember that a tyre with less air in it acts like a tyre with more weight on it, as regards deformations and consequent slip angles, regardless of its construction. Lowering pressure might give you a longer contact patch, which helps longitudinal traction, but it also increases the slip angle at any given lateral force.
    Just Gary likes this.
  8. On my '30 tudor sedan about 3 or 4 years ago I was having a front tire bouncing problem. As soon as I got up to 20-30MPH the front tires would bounce like basketballs, I tried toe -in adjustment, new king pins, shaving the tires to make them more round, even new tires..... you know what fixed it? tire pressure, if I run 32 or more pressure it is fine but less than 30 and they will bounce.
  9. jaw22w
    jaw22w
    from Indiana
    That is strange. My experience with my car is just the opposite. When I try to run 30# on the front they bounce like basketballs. I usually run 22 front and 18 rear.
    C69A and 46international like this.
  10. Yes, I have heard that before. I tried less pressure and it did not help I don't know what made me try more pressure but I did and it worked.
    lothiandon1940 likes this.
  11. lothiandon1940
    lothiandon1940
    ....It's all about harmonics and every car is going to be different.
    X-cpe, '28phonebooth, 5window and 2 others like this.
  12. Petejoe
    Petejoe
    from Zoar, Ohio
    Interesting view points. This gives me a lot to think about. I’ve never run higher pressures on the front end. I will try it.
    46international likes this.
  13. Just Gary
    Just Gary
    Varying tire pressure a few psi can also be used to fine-tune handling.:)
    >To increase understeer, reduce front tire pressure and increase rear tire pressure.
    >To increase oversteer, increase front tire pressure and reduce rear tire pressure.
    Ned Ludd, Petejoe and lothiandon1940 like this.
  14. Blues4U
    Blues4U
    from So Cal
    I think you got one of those backwards.
    Re flat spotting, I think that is something that only occurs with steel belting, right? I've never had a flat spotting issue even after my A pickup has sat for 3 - 4 weeks, which is not often, but it happens. But even then the tires rode smooth right away. Bias ply firestones.
    Re weight distribution, my A pickup weighed out at 1180# front, 980# rear.
    lothiandon1940 and Just Gary like this.
  15. Just Gary
    Just Gary
    Good catch. Corrected.:oops:
    lothiandon1940 and Blues4U like this.
  16. Phil P
    Phil P
    I remember flat spotting as a nylon tire cord thing.
    Phil
    X-cpe likes this.
  17. hemihotrod66
    hemihotrod66
    During my old drag racing days always kept the fronts at 40lbs or more.....Less rolling resistance...
  18. Joe H
    Joe H
    I had some Yokahama tires on my Toyota that would flat spot over the weekend. It took enough driving to create some heat before they rounded back out. Tire make probably has more to do with it them type.
  19. Playing with tire pressure is fine if you're running bias ply, a bad idea if you have radials. Most of the tire 'flex' in radials is in the sidewalls, I'm convinced that most radial failures blamed on 'old' tires is really caused by underinflation in an effort to improve ride quality. Remember that the Ford Explorer/Firestone tire debacle was found to be caused by Ford recommending a too-low pressure and Firestone didn't catch it. Keep 'em at 30 PSI for safety...
