Tire question?
Discussion in 'The Hokey Ass Message Board' started by BigDfromthe303, Apr 20, 2009.
  1. BigDfromthe303
    BigDfromthe303
    Im building my model a that's going to be powered by a ford 460 the long block weighs 700lbs. I would like to run a 650/16 on the front but i'm worried about load rating. Any adivce on what type of tire i need that will be a good match for the weight thats going to be on the front end?
  2. oilslinger53
    oilslinger53
    from covina CA
    you'll be fine. some of the cars that those tires carried had straight 8's that were heavier than any bbf
  3. BigDfromthe303
    BigDfromthe303
    Wheww thats good news. I was told by someone that i had to have atleast an 8 ply radial for the front.
  4. MOCO559
    MOCO559
    load rating on 650-16 is 1580 lbs.
    your fine...
  5. Mr48chev
    As MOCO559 said you should be fine. Remember that the car you are building isn't going to have a lot of extra weight outside of the engine. The whole car with engine and trans probably won't weigh much over 2500 lbs. if that. If you were putting the same engine and trans is say a big Packard with all the t*******s it might be an issue.
  6. JohnEvans
    JohnEvans
    from Phoenix AZ
    Hell the Firestone 5:00x16 dirt style ribs will carry 760 at 32 PSI EACH . Those would work if you wanted to use them.
