Technical TIRE SHAVING/TRUING SERVICE REGISTRY
Discussion in 'The Hokey Ass Message Board' started by john worden, Apr 28, 2016.
  1. john worden
    john worden
    from iowa
    Seems there is a fair amount of interest in this procedure so if you or you know of someone who provides this service list the contact information here.
    John Worden Garage
    405 Green Mountain Road
    Green Mountain, Iowa USA 50632
    PM me or phone 641 474 2313
  2. k9racer
    k9racer
    Minor tire service Decatur Alabama has a tru machine.
    afaulk likes this.
  3. Jalopy Joker
    Jalopy Joker
  4. pat59
    pat59
    Anyone do it near S.E. Pa.?
  5. Barn Find
    Barn Find
    from Missouri
    Yes. I would like to know where this is available.
  6. seb fontana
    seb fontana
    from ct
    J&J Racing, Berlin,CT..Jay Palmer...860-250-8345..
  7. eaglebeak
    eaglebeak
    GMC Co-op in Orlando, Florida.
  8. Nate Jones Tire, Signal Hill, California. (near Long Beach)
    philly the greek and Johnny Gee like this.
  9. PunkAssGearhead88
    PunkAssGearhead88
    from So Cal
    Anybody in Southern Oregon do this as well?
  10. unkledaddy
    unkledaddy
    Gene's Auto Frame & Body
    3100 Kennesaw St.
    Ft. Myer's, FL
    239-334-7427
  11. falcongeorge
    falcongeorge
    from BC
    As far as I know, the Kal Tire retread plant in Chilliwack is still doing it here in BC. You can drop your tires at any Kal Tire, and they can send them there, but they wont know anything about it, you have to contact the re-tread plant first and set it up with them.
    KAL TIRE – INDUSTRIAL, CHILLIWACK, BC (#81)
    43990 Progress Way Chilliwack, British ColumbiaV2R 0C3
    HOURS
    Mon - Fri: 7:30am to 6:00pm
    Sat: 8:00am to 5:00pm
    PHONE
    (604) 795-3388
    FAX
    (604) 795-4334
  12. caton462
    caton462
    We true tires on the car at Advantage Auto in Terre Haute, IN 812 877 6200.
    283john likes this.
  13. Fortunateson
    Fortunateson
    Thanks a lot Falcon
  14. Fortunateson
    Fortunateson
    Thanks a lot falcongeorge!
  15. falcongeorge
    falcongeorge
    from BC
    I hope they are still doing it! Let us know if they are, ok?
  16. k9racer
    k9racer
    Nashville auto recappers.. Nashville Tennessee family owned buss. over 60 years. See Tommy..
    wdglide likes this.
  17. Stogy
    Stogy
    BTTT
    I am in Ottawa, Ontario, Region, Canada So anybody that knows a place this way please help out...sick and tired...:confused::D of getting that 'Shaving tires what is that look'...everywhere I go...Thanks in advance
  18. loveoftiki
    loveoftiki
    from Livonia,Mi
    Stogy likes this.
  19. TagMan
    TagMan
    Probably illegal in NYS :(
  20. bobss396
    bobss396
    Any big truck shop should have the equipment, also those who do 4WD work.
    dan31 and Stogy like this.
  21. car doctor
    car doctor
    Fleming Tire 649 rte. 228 Mars,Pa. 724-625-1577 / 724-625-1090 fax south west Pa. They did my coker tires for me, I can go over 60mph now!
  22. southcross2631
    southcross2631
    Barnes tire in Brunswick, Ga. used to shave and camber our tires for dirt track racing.
  23. 26Troadster
    26Troadster
    wow i really didn't know anybody did this anymore, hell most tire shops don't know what the colored dot on the tire is for.
  24. V8 Bob
    V8 Bob
    Tire shaving is more common now because of modern/sensitive ABS brake systems. All the tires have to be within a certain percentage/measurement of height/tread wear, (depending on vehicle specs) and if, for example, one new tire must replace one on an older set, it may have to be shaved to match the remaining set for a properly functioning ABS. I just went through this on my wife's OT at our local Tire Rack.
    Problem is, they won't shave tube tires like the 'stones on my '32.
    bschwoeble, Elcohaulic and Stogy like this.
  25. Stogy
    Stogy
    Hey all thanks for your input it helps the membership wherever we are...;)
  26. dan31
    dan31
    Yes,it was a common thing for big trucks years ago. Maybe ask some truck repair shops around your location ,they will know.
    Stogy likes this.
  27. john worden
    john worden
    from iowa
    In the TULSA OKLAHOMA area contact Jim Smith at the Hot Rod Garage.
    918-241-6333
    Stogy likes this.
  28. jnaki
    jnaki
    Hello,
    Back in 1959, we found out that some of the new tires, Firestones for the Impala, were not completely round. They were hard to balance. So, our mechanical, genius, friend in Los Angeles told us to go to this place in Torrance to get the tires shaved. We laughed at the thought, but when it was explained to us that those factories pop out so many tires, that it was bound for a lot of tires to show up off kilter.
    This place had a machine that showed how much of the tire was off and where it was not round. In driving the car, it just did not show up as a bump or rock when rolling. But, when the tire was spun on this machine, it showed up as slightly coned on one side. The tire was spun and the machine shaved off some of the rubber tread to get it even. The other tires were in the same shape, so, they got the same treatment.
    The feeling you get when those shavings come off was..there go the total miles on the tread. But for smooth rolling tires and easier balancing, this was the way to go. When it was done, the Impala still drove like it did, but deep inside, we knew it was going to be better in the long run. On the street, we could not feel the difference. For some reason, those early Firestones and Goodyear tires were usually not perfectly round. Most of the manufacturer's tires were the same shapes, not always true.
    Jnaki
    When I bought my first set of Inglewood, Redline, Pos A Traction Wide Tires for the 65 El Camino, I drove over to the same tire place and had the whole set trued and balanced. For wide tires, it did feel different after the truing and balancing. Since this was a pure highway driver, it did make a difference. Those expensive wide tires left a lot of rubber on the ground in order to get them even and true. We went through 2 complete sets over the years owning the el camino with truing each set when new. They were great tires.
    With the better technology on the newer tires, radial and others, they are less prone to odd shapes. But, truing them regardless of tube or not is a precautionary method for smoother driving and longer lasting tires. The next time you get new tires, watch them spin on the tire balancer. If you get the top quality tires, they are pretty even all around with minimal mismatches.
    bschwoeble likes this.
  29. 3340
    3340
  30. Atwater Mike
    Atwater Mike
    We used to do them in Concord, CA.; Concord Safety Center, East bay; owner's son turned business into a respected street rod shop.
    Westbury Street Rods, Concord, CA. Greg Westbury, owner.
    Someone told me he is truing tires with the original machine, from 1968...Hope this helps.
    jnaki and Stogy like this.
