tire size help
Discussion in 'The Hokey Ass Message Board' started by borndead327, Jun 2, 2010.
  1. borndead327
    borndead327
    i just got some "supremes" and i got 2 14in and 2 15in
    my car has 215-75-14 on it now, im planning on running those up front but dont know what size to run on the 15s
    btw the car is a 65 polara 2dr hardtop
  2. billygoat67
    billygoat67
    kinda funny borndead327 i thought i was the only one with this problem.i just did a post for mt 55 wagon front tires. not a easy decision for the right look good luck ,theres alot of good guys no here with alot of good ideas.
  3. borndead327
    borndead327
    yeah i dont wanna keep buying tires just a set to make the rake juuuust right
  4. cryobug
    cryobug
    A 195/75r15 is slightly shorter than a 215/75R14 and requires a 5" to 7" wheel; a 205/75R15 is slightly taller and requires a 5.5" to 7.5" wheel
    If you want somthing wider and about the same height you can use a 215/70R15 also requires a 5.5 to 7.5 wheel width. To get even wider you could use a 245/60R15 that uses a 6.5 to 9" wheel, it to is about the same height as the 215/75R14. I hope this helps
  5. borndead327
    borndead327
