1952-59 Ford Tire size steering effect
Discussion in 'Off Topic Hot Rods & Customs' started by marlinmustang, Jul 21, 2024.
  1. marlinmustang
    marlinmustang
    from Nanuet NY
    Hello all, I was driving up 200 plus miles in my 59 wagon when I had two tires go down. I only was able to get 225/70/15 and not the 215/70/15 that I had one. The car hates the bigger tires. Steering was tighter and was harder to turn at all speeds. Also wonder like crazy at higher speed and hates higher speeds. Just wonder if anyone else had a experience like this.
  2. Adriatic Machine
    Adriatic Machine
    My wife swears that size doesn’t matter
    56longroof and tcoupekyle like this.
  3. nosford
    nosford
    When I worked in a tire store we did a "one size larger" tire installation hundreds of times without any bad results. Usually never noticed much difference unless the tire was MUCH wider or were installed with different wheels that were wider and had a different offset.
  4. JeffB2
    JeffB2
    from Phoenix,AZ
    The OEM tire size on a 1959 Wagon was a 7.50 X 14 which would now be a 205/75/14 the closest 15" would be a 205/70/15 which is two tenths of an inch taller, but the width is the same. Here is a conversion chart. https://tengtoolsusa.com/blogs/news/vintage-tire-size-conversion-chart
  5. bobss396
    bobss396
    How much air is in them? I run 32-33 in my fronts, which are 215/75-15.
  6. jimmy six
    jimmy six
    Personally the skinnier the better so I buy 75 series. For 15” a 205 is the equivalent of a 6.70 and a 215 is the equivalent of a 7.10.
    Your 59 Wagon would hav had 14” rims stock and if my mind can remember the years I changed tires for Sears while going to College; a 59 sedan would have had a 7.50 and the wagon an 8.00. They didn’t get much width until the mid 60’s and the “Wide Oval” showed up.
    bobss396 and tcoupekyle like this.
  7. marlinmustang
    marlinmustang
    from Nanuet NY
    I run 35 psi. I am thinking that something loosened up when I had to drive the tire that went out. Need to check it. And by the way never buy Cokers
    nosford likes this.
  8. Fairlane 62
    Fairlane 62
    Looks like you ran over a porcupine. :eek:
    down-the-road and bobss396 like this.
  9. the-stig
    the-stig
    Like back in the 60s when we all needed a haircut.
