tire size ?
Discussion in 'The Hokey Ass Message Board' started by shitbox2, Oct 28, 2007.
  1. shitbox2
    shitbox2
    i have a ? about tire siz. i am running p235/75r15 on my poncho. there some really big tires . i would like to lower it some more with out it getting out of weird looking. hope to try to get 2 more inches than im gonna put some bags on it this winter so it will almost lay out. what tire size do u guys think i should go to. heres a pic of what it looks like currently thanks eric
  2. Rich Rogers
    Rich Rogers
    Given that you want to lower it more, you might end up with something like a 225-70. That'll lower it some there.With the wheel wells as they are take measurements to see what you can deal with.my .02
  3. shitbox2
    shitbox2
  4. shitbox2
    shitbox2
    any boy else got anything
  5. atomickustom
    atomickustom
    205-75r15 won't look best, in my opinion.
    225-70 would be a bit wide. Maybe 215-70 as a compromise. You can find diameter charts all over the internet to tell you how much smaller they are.
  6. usedall9
    usedall9
    I'm not sure what size ya want, so I cant help you there. But this peice of info might help. If your don't already know??? On a tire that is labled 225/70, The second # (70) means that the side wall is 70% of the tread width. Hence, the smaller the # the wider the tire appears or vise versa. Bigger #, taller tire in that series(225).
  7. 63necker
    63necker
    I went thought this on my poncho as well. The best that I was able to come up with was 225-70. I wanted a larger patch on the ground. They tuck in the wheel wells nice.
  8. shitbox2
    shitbox2
    ok so i found out that im runnin a 29 inch tall tire size .so a 205 has a tire size of 27 0r 26 so does that give me a 2 0r 3 inch drop thanks eric
  9. usedall9
    usedall9
    I believe you will need to devide that # by 2. If I am on the same page as you??? Since a tire is round.
  10. Rudebaker
    Rudebaker
    from Illinois
    (Tire width in mm X Aspect ratio) / 2540 (conversion factor for Metric to English) X 2 + Wheel Diameter = Tire Diameter.
    225mm (width) X 70 (aspect ratio) = 15750mm
    15750mm / 2540 = 6.2007874 Inches
    6.2007874 X 2 = 12.401575
    12.401575 + 15 (wheel dia.) = 27.40 Inches Tire Diameter.
    This will vary slightly depending on manufacturer and model but it's pretty damn close.
