Tire Size
Discussion in 'The Hokey Ass Message Board' started by 51 Leadsled, Mar 29, 2008.
  1. 51 Leadsled
    51 Leadsled
    from NC
    Hey Gang
    I got the money for new tires!!! I am going to spring for new tires for my 51 mercury. I was planning to get the radials. I wanted to pick your brains and see what size works best and if anyone has had a problem with the Coker line
    Coker recommends the P215-75R15 I paln to get the 2 1/2 whitewalls any suggestions?
  2. wetatt4u
    wetatt4u
    Hey John ,
    Whats up guy,hope you and the family are good,
    I'M doing great,
    Thanks for the prayers.....
    I don't really know to much about THE Mercury's ,But IM sure The guys here will set you straight. hahahahahahah
    The cokers WWW will be sweet!....
    Hope to see ya soon.
  3. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    So, does that mean that the old wide whites are up for grabs when I come down? :)
  4. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    BTW yes Ive run 215s on a Merc, I believe I had 215/70/15 (ground down white walls) but Im pretty sure I also had 215/75/15. I think by definition its a smidge on the wider side, but not to where it would be a problem.
    Bias Ply to Radial Conversion Chart
    </TD><TD cl***=****onheading align=right width="100&#37;">[​IMG] </TD><TD cl***=****onheading align=right width="100%">[​IMG] </TD></TR></TBODY></TABLE><TABLE cl***=contentpaneopen><TBODY><TR><TD vAlign=top colSpan=2>If you want to know what size your original bias ply tire would be in a radial, this chart will help you out! <TABLE width=437 border=1><TBODY><TR><TD vAlign=bottom scope=col>
    P-75 Series
    </TD><TD vAlign=bottom scope=col>
    83 Series Bias
    P-70 Series
    80 Series Metric
    78-Series Alpha
    P-75 Series Rim Width
    </TD></TR><TR><TD scope=col width=65></TD><TD scope=col width=80></TD><TD scope=col width=70></TD><TD scope=col width=59>
    185-14 ​
    </TD><TD scope=col width=62>
    E78-14
    </TD><TD scope=col width=61>
    5-7" ​
    </TD></TR><TR><TD></TD><TD></TD><TD></TD><TD>
    195-14​
    </TD><TD>
    F78-14
    </TD><TD>
    5-7.5"​
    205-14​
    </TD><TD>
    G78-14
    </TD><TD>
    5.5-7.5"​
    P235/70R14 ​
    </TD><TD>
    215-14​
    </TD><TD>
    H78-14
    </TD><TD>
    6-8"​
    P245/70R14 ​
    </TD><TD>
    225-14​
    </TD><TD>
    J78-14
    </TD><TD>
    6-9"​
    </TD></TR><TR><TD>
    165R15
    </TD><TD></TD><TD>
    P175/70R15 ​
    </TD><TD>
    165-15​
    </TD><TD>
    A78-15
    </TD><TD>
    4.5-6"​
    640-15,
    735-15 ​
    </TD><TD></TD><TD>
    175-15​
    </TD><TD>
    E78-15
    </TD><TD>
    5-7"​
    185-15​
    </TD><TD>
    F78-15
    </TD><TD>
    5-7.5"​
    710-15,
    825-15 ​
    </TD><TD></TD><TD>
    205-15​
    </TD><TD>
    G78-15
    </TD><TD>
    5.5-7.5"​
    215-15​
    </TD><TD>
    H78-15
    </TD><TD>
    6-8"​
    230-15​
    </TD><TD>
    L78-15
    </TD><TD>
    6-8.5"​
    </TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
  5. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    I copied that from another thread, but unless its just my browser, I think I just broke the HAMB!!
  6. 51 Leadsled
    51 Leadsled
    from NC
    Thanks Guys,
    So far the feedback is 215/70/15 215/75/15 any other feedback? Every one like the Cokers? They give a discount to Alliance members, not sure if the cost at the shows (going to Charlotte the week) would be the same or cheaper.
  7. 19Fordy
    19Fordy
    Check and make sure you have enough backspace on your wheels so the tires won't hit inside the fender. Stock merc wheels are have a total edge to edge width of 6.5 inches and have a 4 inch back space and came with 7:10 x 15 bias tires. I put a pair of P20575R15's on and found that there is not enough backspacing. I think I will need to have wheels with 4 1/2 inch backspacing or skinnier tires. 49 -51 Lincoln wheels have a total edge to edge width of 7 inches and more backspacing. I think the back spacing on the Lincoln wheels is 4 1/4 in, can't remember for sure.
  8. Ruff T
    Ruff T
    from NJ
    I like the Diamond Back tires. They shave the sidewalls of all lettering so the are totally smooth. dbtires.com
