Hot Rods Tire storage
Discussion in 'The Hokey Ass Message Board' started by flatford39, Aug 31, 2015.
  1. flatford39
    flatford39
    OK I know about the date codes on tires but I just acquired a perfect set of white wall bias plys that I probably won't mount for about two years. What is the best way of storing them??
    I understand that the sun is the worst thing to ever happen to tires so would it be OK to put them in a black plastic bag and store them in my garage attic.
    There is no heat or air up there...should I be concerned???
  2. Rusty O'Toole
    Rusty O'Toole
    Put them in the ba*****t, in the darkest coolest place you can find. Put each tire in a plastic bag and lay them flat.
    Model T1 and SanDiegoHighwayman like this.
  3. Sun and heat are the two main enemies of rubber....
    SanDiegoHighwayman likes this.
  4. metlmunchr
    metlmunchr
    Tire manufacturers store them standing up, out of the sunlight, and not wrapped in any sort of impermeable material like a plastic bag.
    Back when tires were wrapped for shipment, the wrap was a non-adhesive paper tape wrapped continuously around the tire. Protected the tire but let it breathe.
    lothiandon1940 likes this.
  5. Ozone and oxygen are very bad too. they react with rubber, heat speeds up the rate of reaction, ultraviolet light in sunlight catalyses the reactions.
    If you can get a really good seal on the bag you might be able to store them in a gas that will not react with rubber but that is getting pretty exotic for most of us. I sometimes store material in Argon in a sealed can. but airtight tire sized cans are hard to come by. The military stores engines in them.
    If the tires are older than just a very few years, your best bet is to sell them, I'm told that the rubber in new tires does not last.
  6. HOTRODPRIMER
    HOTRODPRIMER
    Don't store them in the attic,it gets like a furnace during the summer. HRP
    buickvalvenut and lothiandon1940 like this.
  7. I got a pair of rollers hanging in my garage along with tubes. The tubes are pretty much dust now and the rollers were good tires 6 years ago when I hung them they are now all dry rotted.
    I used to know a guy that wiped his tires down with petroleum jelly and wrapped them in burlap for storage. it seemed to work well enough. I have wiped them down with tire dressing before with good luck. never tried the vasoline deal though.
  8. 3wLarry
    3wLarry
    from Owasso, Ok
    hang them on the wall in your climate controlled house...put mirrors or pictures in the centers for a great conversation piece
  9. lothiandon1940
    lothiandon1940
    Do not store them near anything with an electric motor like your compressor or furnace.
  10. chaos10meter
    chaos10meter
    from PA.
  11. lothiandon1940
    lothiandon1940
    Electric motors create ozone as they operate and ozone is a killer for rubber.
  12. czuch az
    czuch az
    You'll get a good deal in two years too.
    Thats what I tell myself.
    Sometimes I'm an oracle, sometimes a dammed liar.
  13. flatford39
    flatford39
    Thanks a lot guys. Some really great info here. Appreciate all the info. Looks like I will be storing them somewhere in the shop in a dark corner away from the compressor and any sunlight.
  14. stimpy
    stimpy
  15. lothiandon1940
    lothiandon1940
    ^^^^^Good info right there^^^
  16. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Along those lines, maybe toss some Silica Gel Desiccant packets inside the bags? They're in all sorts of stuff we buy. I use them in my ammo cans, seems to work.
  17. 49ratfink
    49ratfink
    one thing I learned is never stack them so the black backsides touch the whitewalls. got some big stains on my whitewalls doing that once, and they were only off the car for a couple months
